Oil leak from top of engine
Old Jul 6, 2003 | 07:27 PM
T/A gets T&A's Avatar
I've got an oil leak somewhere on the back of my engine. It only leaks when the car is running, but it's getting worse. I was thinking it was my valve cover gaskets, but is there some sort of seal at the distributor? There's alot of oil back there! I was just looking for suggestions before I go tearing into it.
Old Jul 6, 2003 | 10:56 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Re: Oil leak from top of engine
Yes it could be leaking at the base of the distributor or at the rear of the intake manifold.
Old Jul 7, 2003 | 09:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those 2 things are definitely suspects. Also, check the oil pressure sending unit, right behind the dist. That's the most likely to be a severe leak. It can literally pour oil out.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
