What would make a TPI bog down when the gas is pushed?
Old Oct 6, 2000 | 09:51 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I drive an 89 305 TPI 5 speed. Yesterday I went to push the gas and found that the car wouldn't move. The RPM's would not go up and would slightly move down. After sitting for a while the car would just cut off. I have a feeling that it is the fuel filter but it really isn't that old. But when the filter is clogged do you guys think that that sounds like the symptoms? Thanks for the help.
Old Oct 6, 2000 | 10:39 AM
MIKES 88GTA's Avatar
Mine did this one night but I had two completely burnt out plugs, an original fuel filter and a bad tps. NO power and my exhaust manifolds were glowing red from the fuel loading up.
Old Oct 6, 2000 | 10:40 AM
IrocManiac's Avatar
It could be the fuel filter. Also there is a chance that the computer is off. Mine was doing that last year and idleing really bad and I took it to the shop and it ended up somehow the computer calibrations were off. They fixed it for about 50 bucks. Then here within the last couple of months it did it again and I replaced the fuel filter and it is fine again.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 6, 2000 | 12:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your cats could be broken too, and one of the pieces inside is blocking the exhaust outlet.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 6, 2000 | 02:43 PM
rondubbs's Avatar
you could have a bad/clogged injector.. run some fuel system cleaner through the system with high octane fuel.
Old Oct 6, 2000 | 02:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Darkhorse, did the idle stumble before the car died? If so, go and unplug your MAF and then try starting it. Post what happens.
Old Oct 6, 2000 | 04:38 PM
86Trans Am's Avatar
fuel filter
fuel pump (mine just died a slow death)
wires to the ecm loose
clogged cat
Mine also had a wire frayed on one of the injector boots which casued it to bog down and buck before it would take off. It could be a ton of stuff, scan it.
Are you getting any codes??
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Oct 7, 2000 | 07:47 AM
84IROC's Avatar
When was the last time you changed the fuel filter and the air filter?
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Oct 7, 2000 | 08:34 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Thanks for the replys. I was right it was the fuel filter but it also burnt out my pump at the same time. To fill you guys in on the other things you posted... I have a new cat, my plugs are about 2000 miles old, I have run injector cleaner through the system enough and it still doesnt help, I have tried to unplug the MAF and it will start but it wont rev up at all. It will just sit there and then die. And the worse part was I had no codes to hint me in any direction. It is getting fixed now but they have to unweld my exhaust so it is taking forever. Thank a ton for all the help I really love this site it saves me money all the time.
customblackbird
Aug 15, 2021 10:16 PM
mustangman65_79
Sep 1, 2015 03:51 PM
lakeffect2
Aug 23, 2015 08:44 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
