Engine swap?
Engine swap?
I just bought my '86 z28 and the person I bought it from said that they swapped a rebuilt 350 in there about 30k miles ago.
How do I tell if they did and if they did what kind of 350 is it?
BTW factory its a Lg4 and it still has single intake and the carb
speed is a good thing,
more speed is a better thing
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A block casting number will tell you if it's a 305 or 350 block. Pull the valve covers and get head casting munbers also.
Other than that, it's hard to tell how long an engine has been in a car and how much milage. A rebuilt engine can fail in 1000 miles or can easily go for 100,000 miles depending on the rebuild.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
theshackle
Mar 5, 2017 06:37 PM
