383 and t-56 question
Old Oct 7, 2000 | 03:23 PM
rage707's Avatar
If I were to use a t-56 tranny with a 383 in an 84 Z28 what kind of flywheel/flexplate would I need, and should I have it externally balanced even if each part is balanced?
Old Oct 7, 2000 | 03:41 PM
ede's Avatar
ede
you'd use a flywheel with a t56. is your engine internally balanced? you'd want the flywheel balanced the same as your engine. i'd think the machine shop would of wanted the flywheel when they did the balancing.
-=ICON MOTORSPORTS=-
Old Oct 7, 2000 | 07:01 PM
89ROC's Avatar
The T-56 flywheel will only bolt up to engines with a 1-piece rear main seal.
Only 87 and up engines have the 1-piece rear seal, which has the correct bolt pattern for the T56 flywheel.
If you 383 is older than 87 you will need a custom T56 Flywheel. Centerforce makes it and it ain't cheap.
Good luck!
AKA Pony Punisher II on all other boards.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
