350 Rebuild Q.......
Old Oct 7, 2000 | 11:17 AM
B L A D E's Avatar
I am going to be picking up a 350 4 bolt main eventually. I wont have alot of money at all. What I want to know is, can I rebuild it WITHOUT a machine shop?! What cant I touch without a machine shop? HOw good can I make the rebuild...what are my alternatives?? Who makes a good rebuild kit, and what does it usually run for?? Thanks...
Old Oct 7, 2000 | 03:54 PM
ede's Avatar
ede
sure you can do it with out a machine shop if your engine isn't wore too badly. you'll still need to hone the bores and change cam bearings, something most people leave to machine shops. rebuilding the heads would be where you'd really need a machine shop. it's a lot better to do it right than save a few bucks.
-=ICON MOTORSPORTS=-
Old Oct 7, 2000 | 04:15 PM
leatherneckm's Avatar
yeah, what ede said. If you're looking for a rebuild kit, buy a super chevy or high perf. pontiac. PAW also has some good kits.
Old Oct 7, 2000 | 04:29 PM
B L A D E's Avatar
ED, whats the average cost for the bores to get honed and the cam bearings changed??
Thanks for the help so far.
Old Oct 7, 2000 | 05:13 PM
Blade's Avatar
I rebuilt MY engine in my garage with no trips to the machine shop. I bought TWO cases of carb&choke cleaner (24 cans) and went to town on the block. It came out sqeeeky clean. LOL Sprayed it with WD 40... Honed it and started the assembly process with new bearings, oil pump and rings. Put it toghether with new gaskets and with my rebuilt heads on top. It runs GREAT and the oil is still VERY clear after I put about 300 miles on it
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 7, 2000 | 10:17 PM
FastBroker's Avatar
Why would you wash your block with carb cleaner, man? All you need to use is Palmolive and some very stiff bristle brushes and a garden hose... Works well and fast! Then dry it fast using compressed air to get the oil passages dry and spray down w/oil/WD40/etc to keep it from rusting...
Oh, if you have 300 miles on it, change the oil and filter...
[This message has been edited by FastBroker (edited October 07, 2000).]
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
