help, my wipers are only coming up 3 inches and then going back down
Old Oct 7, 2000 | 12:47 PM
jasons86iroc's Avatar
they only come up 3 inches and then go back down and then back up. what is the problem? please help me.
Old Oct 7, 2000 | 01:13 PM
Locry's Avatar
it may be a loose connection at the drive motor, the 3 inch travel you're talking about is the hideaway feature, which means the switch at the wheel is working since it triggers the motor. mine has 3 separate connectors on the motor housing, the single wire one is responsible for the hideaway thingy, the others are 3 wire i think, one goes to the washer pump, the other goes to the motor...check that one... or you could try removing the plastic covering and tap the mechanism, something may have jammed up however unlikely...
Old Oct 8, 2000 | 01:07 AM
Vader's Avatar
Jason,
That means your windshield is WAY too tall. You need a chop-top 'F' car with a 3" windshield (that would be TIGHT!).
Locry is right on. You either have a control problem or a defective wiper motor park switch or solenoid (inside the wiper gear case). I fought this on a Cadillac until I had the whole upper end of the column in my lap, only to determine that the $29.00 lifetime replacement wiper motor was FUBAR. There is a tangle of gears and switches in the wiper gear case that switch between the wipe function and park function, depending on power to some solenoids, motors, etc. Another $29.00 "lifetime" motor solved my problem.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited October 07, 2000).]
colton_carlson
Mar 8, 2019 12:21 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
slade5612
Aug 11, 2015 07:19 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
