whinning
Old Jul 11, 2003 | 03:21 PM
DreamState21x's Avatar
whinning
Ok this is kinda weird.. The other week my car started making this noise.. If i rev the engine when the revs are coming down I hear a fairly loud whinning sound, almost like a super charger would make when it is whinning down.. It also does when im driving... When im slowing down for a stop sign it also does it, and when I accel. but it stops after 30.... Anybody know what this could be..Timing chain maybe?? I would have thought something to do with the tranny but it does it when it's in park and I rev it up...
Old Jul 11, 2003 | 03:26 PM
Morley's Avatar
Make sure all accessories are tight along with the alt fan. Check to see if the water pump shaft has any side play.
Old Jul 11, 2003 | 03:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So where's it coming from? Front of the engine? Bottom rear? Top? etc.
Once you've narrowed it down to a general area, go get a piece of heater hose and stick it up your ear (I just love telling people to do that!!!) and use it like a stethoscope, probe around with the other end of it until you find where it's coming from.
Old Jul 11, 2003 | 04:52 PM
area
It's coming from the front of the engine somewhere, I have a car stethescope and im going to try that when I get home tonight.. Thanks morley I'll check that too..
Old Jul 11, 2003 | 09:49 PM
alt
well it's coming from the inside of the alternator.
Old Jul 11, 2003 | 10:27 PM
iroc22's Avatar
Well you've answered your own question now I guess. You will need a new alternator as probably you have bad diodes and it is creating an electrical interference which makes the whining sound.
Old Jul 12, 2003 | 01:10 PM
bearings
Ok, I found out that the bearings are about to go out in the alternator, but on my way home it stopped.. It doesn't do it anymore.. weird... Im gonna let it cool for a little bit and crank it up to see if it is still doing it..
Old Jul 12, 2003 | 02:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter if they're still whining or not when you get home, they're still fornicated.
Get a new alternator. Wasted bearings don't grow back like fingernails or something.
Old Jul 12, 2003 | 06:51 PM
Morley's Avatar
Re: bearings
Time for a rebuild kit.
Old Jul 13, 2003 | 04:19 PM
I know that
I know they don't fix themselves I was just saying that it stopped making the noise.. I was on my way home from picking up a new alternator...
Old Jul 13, 2003 | 04:23 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
besides heater hose, you could use a stethascope, or a peice of metal. Just use your hand as a cup over your ear.
Old Jul 14, 2003 | 12:19 AM
Dan88IrocZ's Avatar
Did someone touch a sensitive subject? You sound as if you were literally offended.
ja87
Feb 23, 2013 07:58 PM
seiplentz
May 24, 2007 06:32 PM
xjcamaro89
Mar 27, 2007 10:35 AM
Shake Zula
Mar 20, 2006 05:09 PM
