Exhaust leak and Pic of copper gasket
Old Jul 12, 2003 | 01:33 PM
Vegeta198's Avatar
i noticed my car making that ticking sound at idle...and at WOT the exhaust note will make this awful loud drone sound......here is a pic of the copper gasket....do those black areas indicate that exhaust is getting out?
Old Jul 12, 2003 | 01:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
yes... alot of exaust is escaping past the gaskets. Probably caused by the botls loosening or the copper gasket failing.
Old Jul 12, 2003 | 02:01 PM
Vegeta198's Avatar
do i have them in backwards maybe?....the side you see in the pic was the side the header flange was bolted to.....this is correct right
Old Jul 12, 2003 | 08:42 PM
Vegeta198's Avatar
any tips on how to fix this? hopefully i can reuse these gaskets
Old Jul 12, 2003 | 09:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
To me, those look like a combination of 2 things:
1. The wrong gasket; those are the large round hole; with practically any stock heads, you need the small square hole
2. Loose bolts or bad flange
http://www.mrgasket.com/mrgmain.html click on the "Online Catalog" for Mr Gasket, go to about page 10; you need the part # 5900, looks like you have 5902 or maybe even 5904, won't fit your heads, specifically the ring is outside of the flat machined flange it's supposed to seal to
Old Jul 12, 2003 | 10:42 PM
Vegeta198's Avatar
wait i thought the stock heads were round port
Old Jul 12, 2003 | 11:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can use the round port gaskets if you have headers that are round.
since its all of the cyls and not just one or two, what that looks like to me is that the header bolts wernt tight.
Old Jul 12, 2003 | 11:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
also, make sure the head mating surface is clean... if its painted, use a block and sand it smooth and clean.
i used copper gaskets for 2 years without leaks. and they were reused many times.
Old Jul 13, 2003 | 08:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
We are talking about a small block Chevy, no??
Old Jul 13, 2003 | 02:08 PM
Vegeta198's Avatar
i reinstalled the gasket, tightening the header bolts from the center two then outward.....cranked it....no ticking or leaks idling and revving....however, when the car is in 2nd or 3rd and you floor it, it's making that weird drone sound
Old Jul 13, 2003 | 03:23 PM
joshwilson3's Avatar
Old Jul 13, 2003 | 03:40 PM
Vegeta198's Avatar
Originally posted by joshwilson3
Hey vegeta, how old are you? I used to live in Humble Texas.
Josh Wilson 21.
23....graduated from Humble High in 98....Baylor in 03
Old Jul 13, 2003 | 04:55 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Our Tahoe does that ticking sound, but it kinda stopped, but when you get on gas it does do it some, but it used to be worse. But it dont got copper gaskets so I can't help you there.
Old Jul 14, 2003 | 03:07 AM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
