Fuel pump doesn't turn on, need help quick!
Old Jul 12, 2003 | 03:08 PM
BlacKnightsZ28's Avatar
The car is an 89 Firebird Formula 305 TPI with a T-5 tranny. The car will turn over, but I don't think it's getting any fuel. There's spark, but I can't hear the fuel pump turn on. We dropped the tank, replaced the pump, but still no-go.
Suggestions? Someone said check the relay, where is that? How do we check it?
Any help would be GREATLY appreciated!
Old Jul 13, 2003 | 12:17 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
supply a 12 volt positive charge to the "G" terminal on the ALDL and that should kick the pump on. Make sure your key is on if you supply a 12v from the fuse panel. If your pump comes on, you've probably got a bad relay. Let us know what goes on.
Old Jul 13, 2003 | 02:29 PM
Thanks so much! If we would have tried that first, we probably could have avoided the work of dropping the tank and the expense of a new pump
So, the pump does come on if we supply a 12 volt charge to the G terminal in the ALDL. So, you said it's probably the relay right? Where is the relay located in the engine bay?
Old Jul 13, 2003 | 03:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
on the firewall next to the brake booster. the inner one should be the fuel pump.
oh, and call me old fashion... but i just jumper the relay plug as if the relay was "on" to test for voltage in the rear...
Old Jul 13, 2003 | 03:27 PM
Vicious 88 GTA's Avatar
what is the G terminal on the ALDL....I got the same problem!!!! AHH!!!!
Old Jul 13, 2003 | 04:06 PM
Under the dash just above your feet on the drivers side is your ALDL. It looks like a connection for a computer or something of that sort. The hole on the lower-left is the G terminal. We just ran a bit of wire off of one of the fuses in the fuse box (also under the drivers side above your feet) to that terminal, and turned the key to the "on" position in the ignition, and we could hear the pump turn on.
Old Jul 14, 2003 | 03:15 PM
did the 12volt thing, heard the pump, got a new relay, still no start!!!! whatsup with that....could it be the , dare i say, fuel pump or is there anything else i could do...AARON
Old Jul 14, 2003 | 03:20 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It sounds like the fuel pump fuse up by the battery has blown then. It is a 20amp sealed fuse up by the battery, I beleive on a 89 Firebird it is on the rad support by the battery. This is what it looks like.
Attached Thumbnails Fuel pump doesn't turn on, need help quick!-picture-188small.jpg
Old Jul 14, 2003 | 03:25 PM
nope, just checked it, the fuse it fine, if my pump was bad would it still turn on and make that sound while i supplied the 12vlt charge to the G spot on the ALDL - AARON
Old Jul 14, 2003 | 03:35 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
No it wouldn't. So there has to be a bad wire somewhere, like around the relay or from the fuse mentioned itself. Check for voltage at the realy and the fuse. Just becasue it looks good doesn't mean it is.
Old Jul 14, 2003 | 06:04 PM
i did notice some wires around the relay plug that were all black and grimey and some were stripped, i will check them later tonite or tomorrow, got stuff to do right now...thanks
Old Jul 15, 2003 | 08:33 AM
Rand's Avatar
Well we fixed mine. BlacKnight and I found my fuse, thanks to you guys here. Who'da thought they'd put a fuse infront of the batter?
Anyway, that was the problem all along, even though we replaced the pump and the relay first, because we couldn't find the fuse. hehe.
So thanks. Tons of help.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
