sometimes i really do think i am stupid!
Old Jul 12, 2003 | 09:31 PM
icebird_1981's Avatar
k well tonight i noticed that i was running low on power stearing fluid so i went and grabbed a bottle out of my trunk that i though was power stearing fluid, that turned out to be carburator cleaner. i pored about about 25% of the bottol in. started the car then shut it off realiseing what i did. i drained out all the fluid, and put in the right stuff but now when i turn hard any direction is squeelz and is choppy . any ideas on what to do next to fix this problem?
Old Jul 12, 2003 | 10:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Remove the return hose and route it to a catch container. Ready to add more, start the engine, and flush a couple of quarts through, adding fresh to the resevoir as it is pumped out. Shut it off, reattach the return, fill to proper level.
Old Jul 13, 2003 | 06:58 AM
ede's Avatar
ede
what five 7 said and to ad to it it wouldn't hurt to reduce the size of your pic in your sig
Old Jul 13, 2003 | 05:58 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Jack the front wheels up off the ground and with the engine not running turn the steering wheel lock to lock a few times. This will bleed all the air out and cause it not to squeal when you get done flushing it.
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
