Riddle Me This .........
Old Jul 13, 2003 | 11:32 AM
Jynxed86TransAm's Avatar
A/C on & Temperature Gauge stayes buried ?!? Any help anyone ??
Old Jul 13, 2003 | 12:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Does the temp gauge work normally otherwise? Is the engine in fact running hot?
Old Jul 13, 2003 | 12:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You mean as soon as you turn on the A/C switch, the needle buries?
Or..
While driving with the A/C on, the needle climbs and buries?
Old Jul 13, 2003 | 01:22 PM
as soon as the switch is turned on the needle goes all the way to the 260 ( not while driving with a/c on) already been there so i dont even use the air.
Old Jul 13, 2003 | 01:24 PM
the gauge hasnt worked at all
Old Jul 13, 2003 | 01:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Your gauge sending unit is on the driver sdie head, between (and below) #1 and #3 plugs...may want to pull the connector and do some continuity check to ground...really seems like yuou have a wiring fubar somewhere...should be no relation to the gauge and A/C switch.
May not be a bad idea to check the ground from the firewall to the pass head, smallish braided ground strap. In fact, check all the grounds too behind the head, just for grins.
Old Jul 13, 2003 | 02:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like you have a mis-wired car.... somebody hooked all the dark green wires under the hood together.... the green wire that goes to the fan switch (in the pass head) and the ECM to turn on the fan, is cross-connected with the green wire that should go to the temp gauge sender (in the driver's side head)
Old Jul 13, 2003 | 06:37 PM
thanks ....
C409
Jan 21, 2016 08:29 PM
dodger65
Jun 18, 2005 05:53 PM
FLYNLOW92rs
Jun 27, 2002 05:09 PM
