How can you visually tell 1pc vs 2 pc real seal...
Old Oct 9, 2000 | 12:22 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
with an engine that is bolted in the car. I need to know what I have in mine. Its not the stock engine.
Old Oct 9, 2000 | 01:58 PM
Blade's Avatar
You'll have to drop the transmission to do it. If you do, you look for a aluminium adapter that fits around the crank and it's held in with 4 bolts. The two piece wont have that "adapter".
Old Oct 9, 2000 | 03:42 PM
myke1984's Avatar
Shouldn't you be able to tell by the location of the oil dipstick? Driver's side means two piece, while pass. side means one piece. Or maybe that is change made some other time, mid seventies sounds familiar for some reason. Sorry if i'm wrong.
Old Oct 9, 2000 | 03:49 PM
Guest
Guest
Posts: n/a
No, the driver and passenger side dipstick wont tell you.
Check where the oil pan meets up to the block in the back, if there is an aluminum housing there just above the pan, then its one piece. You should be able to see it without taking the inspection cover off, but you may have to take it off in which case it will be easy to tell which it is.
Old Oct 11, 2000 | 08:48 PM
lock's Avatar
Car: 86 IROC-Z
Well This should be easy, I dont have an inspection cover on it! Anyone have pics of a 1 pc and 2 pc so I can be absolutley sure?
Old Oct 11, 2000 | 08:49 PM
Jester's Avatar
Get the casting number off the side of the block and look it up.
Old Oct 11, 2000 | 11:06 PM
Guest
Guest
Posts: n/a
Yep.
Its the shiny silver piece all the way on the right. If its a 2 piece rear seal, you wont see that part there.
Old Oct 12, 2000 | 06:52 PM
lock's Avatar
Car: 86 IROC-Z
Thanks everyone! Madmax that picture was perfect. I have that so I guess mine is a 1 pc which is perfect. That means the T56 flywheel I have should work.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
