HELP..vacuum diagram
Old Oct 12, 2000 | 02:03 PM
speeddevil's Avatar
Does anyone know where I can find a vacuum hose diagram for a LB9 engine? I have a very small hard plastic vacuum hose just hanging by the engine top and I can't find where it use to go...
Old Oct 12, 2000 | 09:47 PM
84IROC's Avatar
I believe there are two, one will come from a port on the bottom of the throttle body and go, I believe, to the EGR solenoid. The other should go from that solenoid to the EGR valve. I have the same engine but I basically built it up from scratch so I am not tatally sure that this is the exact factory routing.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Oct 12, 2000 | 09:58 PM
Vader's Avatar
Maybe this will help:
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
timonator
Sep 11, 2015 05:11 PM
