has anyone used sand flap wheels to polish heads???
Old Jul 19, 2003 | 08:18 AM
SlowMaro's Avatar
i saw these lil sand paper flap wheel things at napa and was wondering if 80 grit would do it easier than the lil drums.
carbide cutting tips ordered, ordered 5 of the sand flapper thinggies just in case, they were a buck a piece, 1 inch in diameter.
Old Jul 19, 2003 | 08:33 AM
ede's Avatar
ede
i use them to polish, not metal removal. they work good i na die grinder.
Old Jul 19, 2003 | 08:39 AM
SlowMaro's Avatar
yea i was planning on using the carbide tips to clean up the valve guides and gasket match, the just polish everything.....will i need to use the carbide tips to smooth out the combustion chamber/intake/exhaust ports. or can i just use the flaps.
Old Jul 19, 2003 | 08:47 AM
ede's Avatar
ede
i don't and wouldn't use the flaps in the chamber, i use 2" sanding disk and die grinder after carbide bits.
Old Jul 19, 2003 | 10:28 AM
SlowMaro's Avatar
where do you use the flaps?? in the intake and exhaust ports?
what type of discs, ...flat?? drum type?? what grit?? sorry for all the questions, i just wanna do this right, and only once
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
