is it bad to....
Old Oct 15, 2000 | 11:49 PM
CamaroZ_85's Avatar
is it bad to....
spray carb cleaner into the carb while it's running? i couldnt imagine this causing any damamge....but i was reading this post in the carb board and someone said you really shouldnt.
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 16, 2000 | 07:09 AM
Vader's Avatar
85,
Most spray-type carburetor cleaners are made for this purpose. The major risk in doing this is stalling the engine. I'd rather have the cleaner get burned with the rest of the fuel/air mixture than have it pool up and get sucked into the cylinders all at once when starting. Excess raw cleaner in the clyinders carrying all the flushed-out varnish can foul a cylinder and wash down the oil on the cylinder walls.
Unless you remove the carb for cleaning, I'd rather do most of it while the engine is running. The exceptions would be opening the throttles wide to clean the bottoms of the bores and idle and intermediate fuel ports.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
