gas with 10% ethano?l
Old Jul 20, 2003 | 06:32 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Is 10% ethanol in gas bad for my engine? I have a '89 305 TPI. I was coming home from this girls house and I needed gas badly. It was about 3:00-3:30am so the only close station that was open was a Speedway. Their gas is 10% ethanol. Is that bad?
Thanks,
Matt
Old Jul 20, 2003 | 07:02 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
In a lower concentration such as what is sold commonly (10%) it's not all that bad. Almost every station around here contains 10%! I would prefer not to run it that way, but I really don't have much of a choice!
Old Jul 20, 2003 | 07:03 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
no problem, good stuff
no, its not bad, we sold it at my work too.
the 10%ethanol will actualy have a *cleaning* properties for your injector, and have also a higher octane that plain regular. also better gas mileage, proven fact.
i know for a fact that using ethanol makes it cleaner on the valves and piston, we hard a car with a blown head gasket (external leak) and he used ethanol for years, the piston and valve were brown and by using just a rag and brake cleaner everything came off, no carbon deposit... (pontiac 6000 with v6).
i dont use it in my car because i use "Super", make best mileage and super smell good too ya you read that right, it smells better
Old Jul 21, 2003 | 08:41 AM
Vader's Avatar
It can allow better mileage if you tune for it. Since it tends to detonate a little less, you can usually advance the timing a bit more and enjoy the benefits. If you don't tune a little for it, you can actually get about the same mileage or slightly less at low RPM cruising.
It generally does a very good job of cleaning system components, and lowering emissions of NOx and CO.
Old Jul 21, 2003 | 09:07 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I think the magic statement is that you tune for it. I have run "gasohol" in my 68 350/holley 4spd/4.56 car before and it ran like crap. For one reason the alcohol tries to clean up everything in the fuel system and it ends up in the fuel filter. I would not recomend it for a car more than a year old because of that.
Old Jul 21, 2003 | 10:38 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
thank you vader
I just know on that stuff my gas milage drops even when using the cheapo stuff I normally do.... man I love 87 octane
but then again nothing does damage like the 92-93 does
go from 280-340 miles per tank down to
160-200miles per tank
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
