Edelbrock Performer RPM
Old Jul 20, 2003 | 06:44 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
what will this intake do for my stock L69 4 bbl or should i get the Performer EPS intake? remember, everything is stock and i plan on keeping it stock other than exhaust until i get my 350.
Old Jul 20, 2003 | 07:11 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Go with the eps since it's got the stock cam in it. I don't think the regular performer would do much since it's basically a stock replacement. The RPM's pulling range is a little high for a stock 305.
Old Jul 21, 2003 | 03:42 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Performer RPMs often won't fit under the hood of a 3rd gen
And an ordinary Performer is much better than a stock intake, to the tune of about 20 hp.
Old Jul 21, 2003 | 08:50 AM
jimmy_mac's Avatar
Re: Edelbrock Performer RPM
Does the EPS come with a Q-jet base configuration? I thought it only had the holley pattern.
I swapped out a stock Q-jet manifold for the RPM on my 350 with a 269HR cam. My et and mph didn't really change much at all. But it was a much hotter day when I ran with the RPM. But the 269HR cam runs to about 5600 rpm which is the limit on the regular performer, so I probably didn't need the RPM.
I'm not saying you won't see an increase in power. It just may not be really significant with a stock set up.
Old Jul 22, 2003 | 05:00 PM
chio987's Avatar
Engine: 305 4bbl HO
so a normal performer adds 20 HP?
Old Jul 22, 2003 | 07:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It might, if tested on a motor that already had all other restrictions to performance removed. In other words, real good-flowing heads, a nice cam, large-tube exhaust, maybe some more CID, etc.
I doubt it would add as much as 5 HP to an otherwise stock L69.
Old Jul 22, 2003 | 08:25 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
An RPM will fit under the stock hood. Might have to use a drop base element tho.
I have a holley street dominator intake (idle-7200rpm) and its taller than the RPM airgap my friend has.
Old Jul 22, 2003 | 08:34 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I put on a eps, hooker headers, true 2 1.5 duals, and a 750 carb on a 85 305 truck engine. practically the same as a 305 in your car. Had no bottem end, but the midrange and top end was something to brag about. that is just my .02 cents
Old Jul 23, 2003 | 07:23 AM
(BR)G-Machine's Avatar
I bought an EPS and I dont like it. I like the performance of it because you do get like 10 horses on more just on the better designed flow paths, but I dont like that it is essentially the same intake as the US duty stokers. Consider this one-
Yes! It is a single plane and emmisions legit! WOW! Just personally I like single plane intakes alot more, because I think that they seem to be alot more Cam compatable; like a performer Rpm loves low duration cams and low rpm but unless you are running high carb cfm, it suffers from chokage on the pressure waves when you start going high Rpm or long strokes. O well, different post for that though.
But if you are considering getting an RPM then maybe that one is up your alley.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
Jorlain
Oct 8, 2015 01:57 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
z28guy134
Sep 1, 2015 11:50 PM
