Do I have a bad fly wheel?
Old Jul 22, 2003 | 01:24 AM
jayhah2's Avatar
Ok guys, Ive had this car for almost 3 years now. Im about ready to install my 4th Starter!!!!!! I dont know what is causing my car to eat these things up like there candy, I thought it was heat soak so i put a heat shield on the starter but it just went out again on Friday. So could it be that my fly wheel has lost some of its teeth??? Any help would be appreciated. This is really starting to get nerve racking.
Thanks,
Jay
Old Jul 22, 2003 | 01:32 AM
deadtrend1's Avatar
Did you need to shim the starters when you installed them? Any noises when you crank it when the starter actually worked? I seriously doubt you lost teeth off the flywheel.
Old Jul 22, 2003 | 01:44 AM
jayhah2's Avatar
No I never had to shim anything in the past, for a while it would click when i turned it over, after doing that a couple of times it would start. It did it a couple of times the other day, and then nothing. I just replaced the starter in March with an A/C delco starter. I just dont know why it goes threw so many starters, there has to be something thats causing it. Thanks again for the help.
Old Jul 22, 2003 | 07:21 AM
ede's Avatar
ede
cheap rebuilt starters don't last forever. where are you getting starters from?
Old Jul 22, 2003 | 01:26 PM
jayhah2's Avatar
The last one I purchaced from the GM parts department at our Chevy dealer. It wasnt a rebuilt starter. Im going to get it running at least today, and then take it to have someone look at it. I think I may have an elctrical problem now, after doing some research last night. Thanks again for the help.
Jay
Old Jul 22, 2003 | 02:22 PM
gmsmallblockguy's Avatar
Check your battery connections and main grounds. You should have 2 main hot wires one to the alternator and one to the starter. Also 2 main grounds to check from the battery to the block and the strap(braided wire) from the block to the body.
They should be clean and tight a little vasoline or dielectric grease can prevent corrosion.
A weak connection can burn up electric motors and low current to the starter can cause the "click only" issue you mentioned.
Old Jul 22, 2003 | 07:30 PM
jayhah2's Avatar
Thanks for the advice gmsmallblockguy, Ill check that out tomarrow, i ran out of daylight today. Thanks again guys.
Jay
Old Jul 23, 2003 | 06:46 PM
jayhah2's Avatar
Hey guys found out what the problem was today, it was the Pas Key. I guess that might eplain why the car would start and not start sometimes I wonder if the last 2 starters were even nesacerry now. Anyways thanks everyone for your help.
Jay
Scamo-2.8
May 20, 2016 07:01 PM
B_Dubya
Aug 26, 2015 05:09 PM
milk
Aug 10, 2015 06:26 PM
