Few Mods any gains???
Old Jul 23, 2003 | 08:52 AM
jdrafke's Avatar
WEll i was jsut wondering if u guys think that maybe getting an afpr and setting up my fuel pressure, airfoil, kandns uping the tps voltage. Do u guys think that i maight see a gain with these mods. Any replys are aprrecitated
Old Jul 23, 2003 | 10:46 AM
Vader's Avatar
I didn't. For what you would spend on an AFPR, you can purchase a die grinder instead, then port your plenum behind the throttle body and match the runner openings better. That will give you a bit more flow at higher RPM. The AFPR won't help much if the rest of the engine is stock, unless you have an injector flow problem.
Old Jul 23, 2003 | 01:58 PM
jdrafke's Avatar
thanx for the reply um...my fuel reg is bad on the car now so wither way i need a new one, im gonna port the plenum when i do the afpr with my buddy who does it, and the other mods will they make for any gains that i can feel
Old Jul 23, 2003 | 09:57 PM
Vader's Avatar
Well, that's a different story. As long as the regulator is toast, it would only make sense to replace it with an adjustable unit. I thought you were planning to do it just for the sake of having an AFPR.
Old Jul 24, 2003 | 12:34 PM
jdrafke's Avatar
well yes i suspect the regualtor but it could be other things as well. But im gonan replace it with that. I plan on porting the plenum, turning the tps voltage up a bit(more torque), airfoil, kand ns, and perhaps a ram air stup of sum kind. How ahrd is it to set one op that wont suck in water when raining. thanks guys.
Old Jul 24, 2003 | 02:26 PM
rumpilstiltskin's Avatar
does turning up the tps voltage actually increase torque?, i thought that was just a myth?
Old Jul 25, 2003 | 02:29 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like a myth to me. I can't see how upping the voltson the throttle position sensor would affect the power output at all.
Old Jul 25, 2003 | 02:54 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
IIRC, increasing the voltage on the TPS fools the ECM into thinking the throttle is open more than it actually is. This causes it to go into Power Enrichment mode sooner. I'm not sure if that really has that much of a gain though. Maybe someone else could answer that one.
Old Jul 25, 2003 | 08:57 AM
jdrafke's Avatar
yea my buddy kieth had told me about htat i had never heard of doin it before. how about the other mods? and the ram air setup which i hear is a very good gain...
Old Jul 25, 2003 | 09:10 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The custom Ram Air is a good "Free" mod. It helps throttle responce. You won't get much on the dyno since the car isn't moving. The fan that most dynos put in from of the car really isn't enough to test the ram air setup.
Old Jul 26, 2003 | 11:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"Ram Air" doesn't ram anything. That's not where the gains come from. What its benefit actually is, is in picking up cold dense air from in front of the car, rather than hot thinner air from under the hood or around the radiator. But most always, on a chassis dyno, the hood is open anyway, so the motor typically gets reasonably cool air whether it has CAI or not. If you dyno'ed the car with the hood closed, you might see a considerable difference, with or without CAI (Cold Air Induction, affectionately known for some reason as "Ram Air")
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
