anything wrong with my setup
Old Jul 23, 2003 | 07:10 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
Well I finally got my car back together and running good. But it feels slow. I just put the heads and intake on. I noticed a difference but not all that much. Going from stock 081 heads to vortecs should be a pretty gain right? The initial timing is advanced to 10* if that makes a difference. But I dunno whats wrong if anything. I was just expecting this to make a little more power than it has.
Old Jul 23, 2003 | 07:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure you had 081's (305 TPI heads) or 083's L98 heads?
If 081's, then what you lost in CR, but gained in flow...may have worked out about even?
Old Jul 23, 2003 | 07:51 PM
Killogy's Avatar
Engine: 355
they were 081's and I realize that I lost compression. But I don't think this car will be able to even break 14.5. I was under the impression that I'd be able to easily hit the 13's.
Old Jul 23, 2003 | 08:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Seems like you had enough motor to get in there, with either heads.
Check the full ignition advance and rate?
Dyno Don
Jan 24, 2016 08:24 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
