Oh Sh!t, Broke bolt off in intake
Old Jul 24, 2003 | 10:15 PM
92BlackRS's Avatar
Oh ****, Broke bolt off in intake
I broke off a bolt trying to change thermostats. It has about
a half inch sticking out, the rest is still in the intake. What is the best removal procedure?
Old Jul 24, 2003 | 10:19 PM
Dirty Rob's Avatar
If its got a 1/2 inch sticking out, you should be able to turn it out with some vice grips.
Hit it with some penetrating oil first, and dont totally torque on it, just use the grips if it will turn out.
Old Jul 24, 2003 | 10:27 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if not try a crap load of pb blaster and a pipe wrench. i've had alot better luck with a pipe wrench than with vise grips.
Old Jul 24, 2003 | 10:37 PM
92BlackRS's Avatar
Thanks for the input guys. I do appreciate it.
Old Jul 25, 2003 | 12:13 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
FYI be very careful and take your time. I had to repair a base where someone had broken that bolt off and tried to drill it out. He failed and I got it for cheap on Ebay
I'd say you could also lightly heat the area but I'd be wary of doing that.
David
Old Jul 26, 2003 | 05:03 PM
lykan's Avatar
Bolt removal
Since you have about 1/2" sitcking out you can try to file the bolt down square, until it matches a wrench perfectly and then just wrench it out
Old Jul 26, 2003 | 09:28 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I would go vise grips first... then pipe wrench (I haven't had luck with those though) then use an ez-out. Soak the bolt with WD-40 either way.
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
