MOTOR BLOW AFTER 300MILES????
Old Oct 16, 2000 | 02:08 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I'm driving home normally, driving normally when suddenly the car sounds like its under HEAVY load, the tach starts going crazy and the engine sputters, lurches and coughs. I look at my oil pressure.. 0 PSI
i immediatly turn the engine off and roll to a stop on the side of the road. I check my oil with dipstick, its full of oil...
I try to start it again, but now it acts like its 180* off on the distributor, (fires, stumbles then quits. ocassionally backfiring out the carb.)
WTF WTF WTF
the engine has 500km on it since rebuild, i drove it like i was told, i just changed the oil, maybe my filter ****ed up???
what could have happened????
over heated? i never really checked the temp before i started walking home. the engine didnt feel hot at all though. oil looked clean on dipstick
but steam came out of the PCV when i took it off.
what the hell?????
Old Oct 16, 2000 | 03:13 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Perhaps during the rebuild something happened with the oil pump. I understand some engine builders actually tack weld them so the pick-up does not drop off. If the engine was full of oil and no oil pressure, sounds like a pump problem to my untrained mind. Sorry to hear about your motor
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 16, 2000 | 03:57 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
dist gear broke, luckly i had a spare one at home
hopefully the cam gear didnt get damaged.
Old Oct 17, 2000 | 01:50 PM
daniel dekay's Avatar
lucky you!
Old Oct 17, 2000 | 07:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Jer, what setup are you running? Did you swap to something other than stock fuel deliv. etc.?
Old Oct 18, 2000 | 12:08 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
my setup is in my sig. im running the stock mech fuel pump.
1982 Camaro Z28
"Vortec 305"
-KIA
Project "VortecZ"
rebuilt 355, GM 9.5:1 pistons, GM Vortec crank
GM L31 Vortec heads, Competition xtreme energy cam, edelbrock Perormer rpm vortec, edelbrock 750 carb, dynomax shorty headers, accel ignition, bosch platniums,edelbrock ProFlo aircleaner, Flowmaster 3 chamber exhaust, Richmond 3.73 rear, rebuilt dif, rebuilt 700r4, modified shifter, homade ramair, factory fiberglass hood,
and some other stuff
"if its broke, dont fix it. just replace with it's high performance equivalent." -Me
Old Oct 18, 2000 | 12:59 PM
chevystud's Avatar
I know this doesn't help any, but sorry to hear about you engine. hope you figure it out soon.
Old Oct 18, 2000 | 08:18 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Jer, did you get all the bits out yet? Anyway, have you checked to make sure the dist. isn't sitting too low. Sometimes on aftermarket intakes this will happen and you'll get the broken gear for all your troubles. Just a thought.
Old Oct 18, 2000 | 08:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
That kinda sucks since the dist. drive the oil pump. But then lucky for you the engine quit before it ran to long.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
inferno15
Aug 29, 2015 01:48 AM
86White_T/A305
Aug 17, 2015 12:16 AM
