questions about 083 L98 heads
Old Jul 25, 2003 | 11:04 PM
billb's Avatar
I keep seeing that the L98 14101083 heads were used on 285 & 300hp crate engines. Does anyone know what cam these motors used? What power can be had with these heads w/out porting? I am looking at an 87 350 out of a g20 van, adding the 083 heads, summit 1105 cam, headers, no cats, and edelbrock performer intake. Just hoping I can at least reach 300hp.
thanks as always:lala:
Old Jul 27, 2003 | 08:46 AM
Vader's Avatar
Bilb,
'083 heads have relatively small port runners, but they are a little larger than many other factory heads. The real benefit is that the chambers are 58cc. That should increase the static compression on your 350. Whether that will get you to 300 HP is questionable, but it should help with torque production at lower RPM. I'm not sure how well that intake is going to compliment the heads and cam, since I don't have specs on that cam grind.
Old Jul 27, 2003 | 08:50 AM
85TPI400's Avatar
I thought the 083s had 64cc chambers!
Old Jul 27, 2003 | 05:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You are correct unless they are alluminum L98 heads.
It is the 081 305 heads that are 58cc stock.
Old Jul 27, 2003 | 10:29 PM
Vader's Avatar
Sorry. My mistake. I'll bet the aluminum L98 heads have a different casting number, too.
Old Jul 27, 2003 | 11:41 PM
Engine: 305-4v
Those are great templates you've posted, Vader!
Old Jul 27, 2003 | 11:44 PM
OMINOUS_87's Avatar
I thought the iron L98 heads were 803? Anyway, I know the alluminum L98 heads are 58cc chambers. Does anyone know for sure what the iron L98 chamber size is?
Old Jul 28, 2003 | 12:50 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
From MorTec:
14101083...87-up...350..........Gen.I, also used on crate motors, 285 or 300 hp, 64cc
chambers, 72' center manifold bolt
angles
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
anesthes
Aug 8, 2015 09:37 PM
