How Do You Clean IAC ?
Old Oct 19, 2000 | 02:37 AM
voltran's Avatar
Old Oct 19, 2000 | 01:24 PM
badbird88's Avatar
what motor do you have? TPI or TBI? Either on is best cleaned by removing the TB and spraying the IAC pintle and passages with electric parts cleaner or a TBI cleaner that is safe to use on sensors. The IAC can be removed but not neccessary.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
