Rebuilding carb
Old Jul 26, 2003 | 08:29 PM
Rage13's Avatar
Car: 89 Firebird
Rebuilding carb
I'm in the process of rebuilding a 600 cfm edelbrock (mech. secondaries and manual choke) and noticed there are a second set of butter flys in the secondaire barrels, they are only connected to a set of waits.. what are the purpose of these and would there be any benefits or harm to take these out?
Its going on a stock 305, only mod that will be made while the carb is on is headers.
Old Jul 26, 2003 | 11:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The upper set of butterflies is an air valve, just like the Q-Jet; except that the ones in that old 50s model Carter from the Stone Age are controlled by weights instead of springs. Very crude. Effective on a car that's sitting still, or maybe on a 54 Pontiac straight 8 car that weighs 5000 pounds and has about 180 HP; but pretty poor for performance use by "modern" standards. But since you bought it, you're pretty much stuck with it.
It's necessary. You can't eliminate it. Just make sure it works as good as it can, that's the best that carb will ever do.
Old Jul 27, 2003 | 01:23 AM
Rage13's Avatar
Car: 89 Firebird
well i got it for free, so the only thing it really cost me was $40 for the rebuild kit... and its only a temp. solution while i work on my TPI setup
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
hotrod1988
Sep 11, 2015 04:39 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
