Best ignition system?
Old Oct 19, 2000 | 11:15 AM
Drowned's Avatar
I'm thinking of buying one, so... what is the best ignition system? and what is the best model to use on our cars? I've heard Jacobs is pretty good, but too expensive What about the other ones? Which one is in second place? (MSD, Crane, Holley, Accel, Mallory...)
Old Oct 19, 2000 | 12:21 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
they are all basically clones of eachother. The accell is the smallest (and possibly the most cost effective). At one time, they had a coil and CD box for about 150 bucks. The basic holley is not bad (I have it). The MSD will probably cost the most if you want to include a rev limiter (because it is optional on the MSD6
Old Oct 19, 2000 | 03:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've got the MSD6AL 169.99 Going to need tach adapter probebly 25.99 and I have the Accel super Remote mount coil 49.99
So for about 250 You can have a good setup.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.2@98
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
