LT-1 starter, quick question??
Old Jul 28, 2003 | 06:58 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Do I have to specify if the starter is for an auto or stick when getting the LT-1 starter for my L98??
Old Jul 28, 2003 | 06:35 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I just went to Advance Auto Parts and told them I needed one for a 96 Z-28. The starters should be the same. One of the best mods I've done so far.
Old Jul 29, 2003 | 06:12 AM
Car: 91Z
Yaa, that's what I ended up doing, said 95 though, same thing. I am installing it tonight. What did you do with the bolts that are too long??
Old Jul 29, 2003 | 08:46 AM
87transam5.7tpi's Avatar
my original bolts went in fine, i don' tsee how they are to long????? the block is threaded pretty high up, or was on mine at least.
Josh
Old Jul 29, 2003 | 11:36 AM
Car: 91Z
thank's man, I guess it will be fine then. I'll get some washer's from work just in case though.
Old Jul 29, 2003 | 06:14 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
go to the dealer and get the right bolts. they are shorter. get them for a 96 Z. i had the same trouble when i put the 96' LT1 starter on my L98. the earlier LT1's used the same starter bolts as our L98's.
Old Jul 30, 2003 | 07:31 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i got one for a 93 corvette. the bolts for me were too long also. used washes to make up the distance. also had to put in a 1/16" shim.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
cRoe4
Aug 7, 2015 08:46 PM
