headlight relay...
Old Jul 28, 2003 | 02:57 PM
dave89gta's Avatar
headlight relay...
Anyone have a wiring diagram for an '89 GTA headlight relay?
I did a search and only found diagrams of earlier years. My lights wont go up or down, and I want to do some diagnostics.
Ok, update; the relay does apparently work. I can hear and see it click when I switch the lights on. On the 4 pin side, all wires (2 green, 2 gray) are seeing 12 volts in both the off and on positions. 3 of the 5 wires on the other side of the relay are seeing 12 volts in the off position. Dont remember which, and dont know about the off position. The motors both work properly off the battery, although the driver's side continues to run after the light is up. The **** never tightens in either direction.
--Dave
Old Jul 28, 2003 | 03:26 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
Dude the 3 bearings in the headlight motors are crumbled you need to replace them.
Old Jul 28, 2003 | 03:33 PM
dave89gta's Avatar
But dont I still have a wiring/relay/harness problem? The motors push the lights up and down when I directly connect them to the battery, but not throught the switch/relay.
Thanks.
Old Jul 28, 2003 | 04:28 PM
dave89gta's Avatar
I put voltage/ground to both sets of gray/green wires at the relay, while the relay was disconnected. Then I plugged in the headlights again and they worked ok. This was the case for both sides. It just doesnt work if I connect the relay. All 4 wires, green and gray, have voltage in both on and off positions. WTF?
I am probably going to go get a new relay, and see if it fixes the problem.
Old Jul 28, 2003 | 04:50 PM
dave89gta's Avatar
Forget about getting that new module. Just called dealer and he gave me a part number: 16523917. Dealer wants $170 for it and gmpartsdirect.com wants $96. Time for a manual switch?
Old Jul 28, 2003 | 08:05 PM
dave89gta's Avatar
Well, if anyone cares, I seem to have found the cause of my headlight woes.
The two fusible links that are circled in yellow are blow. I think this could have something to do with my problem.
I am probably going to resolder the links, although I do not know any of the specs of these fuses. Also, anybody know what stops the headlight motors from running? When they hit the top, or bottom, what stops current from continuously being drawn by the motor? Is the cutoff in the motor, or the relay/module?
Its kinda fun replying constantly to my own posts.
--Dave
ps - sorry for the big picture.
Old Jul 28, 2003 | 10:25 PM
dave89gta's Avatar
I did a temporary fix. I jumped the links with rolled up tinfoil. I am probably going to go get another relay tomorrow.
--Dave
Old Jul 29, 2003 | 12:38 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Is that out of that relay power box thing on the firewall?
See my headlight motors were recently rebuilt. The issue is sometimes my headlights will not go up when I hit the switch. They always come down on their own but only sometimes go up.
Old Jul 29, 2003 | 01:42 PM
Car: '88 Formula
Engine: 355cid
Get back with us when you get the problems fixed. I'm interested in seeing whether it was your relay....I still have my doubts.
Old Jul 29, 2003 | 05:20 PM
dave89gta's Avatar
The "rebuilt" module worked ok last night, then didnt today. I went to the junkyard and picked up a module. I put it in and it doesnt work.
The lights pretty much go down when I plug in the module with the switch off. When I flip the switch, nothing. The relay doesnt switch at all. I can see it just staying in the same position. So, basically, I'm not too happy.
I think I need to rebuild at least one light, however, from what I understand, the motor would still try to spin the light. And it does nothing.
--Dave
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
