fouled plugs
Old Oct 20, 2000 | 07:46 PM
moncito's Avatar
fouled plugs
car keeps on fouling plugs lots of black smoke hrd starting erratic idle fuel pressure drops when pump stops loud sucking air noise from 58mm throtle going craze
Old Oct 20, 2000 | 09:13 PM
Vader's Avatar
Mon,
What year/model/engine do you have?
If you have a fuel injected engine, I would suggest checking the injectors for leakage. if it is a TBI system, you might want to inspect the gaskets on the injector pod for leakage.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 21, 2000 | 05:44 PM
moncito's Avatar
vader my engine is a 91 350 tuned port ported heads cam standard bore ported plenum runers 58 mm throttle cold air super comp headers1 3/4 no smog no cats 3 1/2 inch exaust adj. fpr Today we adjusted tps and iac valve it was idling ok but all the sudden it started surging again erratic iddle no power and black smoke also when the fuel pump stops pressure drops quickly even with the return or preasure line blocked
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
