flushing a/c system
Old Jul 31, 2003 | 06:08 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
flushing a/c system
what is the proper procedure to flush the a/c system? what chemical or solvent is used to flush out the a/c components?
i've searched but found no "procedure" on how to properly flush out the a/c system.
i'm going to replace the cheap *** four seasons crap that's on there now. (chain store reman crap) the "new" compressor is a known good used compressor.
should i completely disassemble the a/c system? the evaporator core has to stay in the car. too much work . how should i flush the condensor? hoses? compressor? what procedure is used? the a/c will be staying r-12. currently the system oil looks to be grayish color (not good).
i know i will have to replace the orifice and the accumulator. does anything else need to replaced? what is the proper procedure to refill the a/c. i know i will put the system in a vacuum after the components are flushed out and clean. when charging i should not exceed 40 psi on the low side correct?
i have all the hvac tools needed except the flush thing. gauges, pump, etc..
please help i want to get my a/c back together asap but want to function properly.
Old Jul 31, 2003 | 06:55 PM
OMINOUS_87's Avatar
This should help, just ignore when they say 134A..
http://www.iroczone.com/newindex.htm
Old Aug 1, 2003 | 08:17 AM
Car: 1988 IROC-Z
that was helpful. the problem i had the last time is getting the first can to go in as a liquid. i couldn't get the whole can in maybe a 1/4 of it went in. the rest stayed in the can. any suggestions?
i don't want to slug the compressor.
junior419
Apr 7, 2025 11:35 AM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
89 formula TPI
Oct 6, 2015 08:40 PM
Mdenz3
Sep 17, 2015 08:36 AM
gta892000
Sep 16, 2015 12:40 AM
