lots of carbon on valve=bad guides??
Old Aug 4, 2003 | 06:30 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys, before I tear my engine apart I just want to make sure that it is what I think it is. Well When I built the motor I didn't have the money to get the valve guides redone so I just cleaned them up and put new seals on them. Now 3500 miles later I get white smoke at high rpm when I shift and sometimes when its idleing it will let white smoke out. Now when I had the heads apart the valves had hard carbon caked on them real bad, about 1/2in thick in some spots, really restrictin flow. Now I just scraped it off and cleaned them and assembled the heads again. Now carbon on the valves means bad valve guides correct??Or should I look elsewhere for a problem? Also It seems to be getting worse and worse. You don't think this coudl be my rings right?? Thanks for any input that you have...
Old Aug 5, 2003 | 01:39 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its shooting white smoke, forget about the rings. Its burning coolant. Its probably a head gasket leak. Unless this is just a cold engine smoking, in that case, its prolly just condesation.
Old Aug 5, 2003 | 11:26 AM
Car: 89 Formula
Engine: Carbed 5.7
How coudl it possibly be a blown head gasket? The engine runs awsome and has so much power, it just smokes a little. Also I burn oil cause i am always low when i check it. And another reason to think its my valve guides is the massive amounts of carbon on the valve and thats a tell tale sign to bad guides..My dad said if i blew a head gasket he thinks i would smoke all the time not just at idle and at rpm when i shift. What are the signs of a blown head gasket? does the engine still run fine?
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Out-Cast
Aug 17, 2015 10:57 AM
