car started to Back fire need ideas
Old Aug 4, 2003 | 08:16 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
Car started to back fire when i let off the gas then at stop lights the rpms where droping like the car wanted to Stall. Any ideas would be great thanks Tim
Old Aug 4, 2003 | 08:34 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
My 1989 GTA 350 TPI did the same thing a month ago. It would backfire, RMP is all over the place and felt like it was running on 4 cylinder. After some research, it was suggested that my coolant temperature sensor could be bad. Sure enough the problem was fixed once replaced.
Old Aug 5, 2003 | 06:36 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
wheres your coolant temp sensor? my secondary one on the block is broken and when it gets hot I flick a swicht to turn it on, but my primary seems to always be on and I got a performance resource chip. Now that you mention it the rpm's only jump around when the car temp is over 190
Old Aug 5, 2003 | 09:11 PM
CC's Avatar
CC
Per pic
Old Aug 5, 2003 | 09:19 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
that would be worth a shot. another thing to look into would be the tps sensor. any codes?
Old Aug 5, 2003 | 10:17 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
no codes check engine light hasn't come on.
Old Aug 5, 2003 | 10:29 PM
Guest
Guest
Posts: n/a
the motor could of jumpped timeing
Old Aug 7, 2003 | 08:00 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Mine backfires all the time... but that's with open headers
Might be an exhaist leak? I'm sure you'd know that it it was though... running to rich?
Old Aug 8, 2003 | 01:28 AM
Trace Cook's Avatar
you might pull the timing cover and check the chain slack...should not be more than .500 inch
Old Aug 10, 2003 | 11:24 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
ok found out that the fuel is ignighting in the tail pipe on the down shift and throttle, but not all the time. would this mean timing is a little out?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
