A/C & Heater Gurus please help troubleshoot and answer questions.
Old Aug 8, 2003 | 11:24 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Ok, got my car a few weeks ago, and its been PERFECT since, except one thing, I lost my A/C, Heat/ Fan, basically my HVAC controls do nothing.
I talked to the guy I got it from (I am not bitter at all, just talked to him to try and troubleshoot) he said it might have cracked the compressor again. He just had it replaced.
If it is a cracked compressor would it take everything else out like that with it. Will it be fixed if I put in a new compressor?
I have a used one, probobly has R12 in it I guess. but the car has been converted to R134. What would I have to do there?
Old Aug 9, 2003 | 05:27 AM
ede's Avatar
ede
just so i understand better the fan works but not the selector switch? if so it's ran by vacuum and most if not all i've seem develope a leak in the diaphram part of the selector switch. pull the panel off and take a look it's where all the lines go to, or come from. you can connect some very low preasure air, like 5 psi, to the fitting under the hood and soap the system for leaks. you can pull a vacuum on it with a hand pump to see if it has a leak.
Old Aug 9, 2003 | 06:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Remove the control head from the dash. Observe the wires on the rear. You will find, in the harness that goes to the "mode" switch, one single brown wire. That wire is the one that brings power from the ignition switch to the entire thing. Follow it back into the dash, where it plugs into the main car harness; about a foot or so in, you'll come across a connector of incredibly stupid design. It will be found to be burnt to ashes. Cut both ends of what's left of it off of the wire, and replace it with a BIG, THICK slide terminal or something; remember, there's ALOT of current in that wire, so use heavy-duty connectors.
There is another of the same type under the hood, that feed battery to the fan high-speed relay. To find that one, locate the blower motor, and fooolw its purple wire back to the relay; there will be a large red wire also at the relay; follow that red wire back over the top of the evaporator housing, and you will come to the connector in question along the firewall just about above the right valve cover. It will probably be burnt to ash as well.
Old Aug 9, 2003 | 09:16 AM
Guest
Guest
Posts: n/a
hey ede isn't there a vac. house on the intake that runs the Hvac controls? shuold he look there first??
Old Aug 9, 2003 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The vacuum runs the little doors that determine where the air comes out. It does not run the fan or the A/C compressor. If he had not vacuum at all, his system would still work, except that all the air would all always come out the defroster, and he wouldn't be able to change that.
This is an electrical problem, like the 4 cars in my immediate family that I have had to repair it in, including 2 thirdgens (one of them being mine), a Monte Carlo, and some FWD car.
Old Aug 9, 2003 | 10:10 AM
86FyrBrd's Avatar
yeah, if I move the selector switch I can hear the flappers and such, I just dont get anything out of it.
I'll open her up today or tomarrow.
Old Aug 9, 2003 | 01:24 PM
86FyrBrd's Avatar
ok dont attack me to bad, I checked all that and they were PERFECT, then I realized 'Oh Sh**, I never checked the fuse!"
Sure enough that was it, BUT, the A/C Still dont work, I didnt notice green stuff (R134 Im guessing) on the back of the compressor, got curious so I pushed the schraeder valve on the condensor (I'm guessing, I dont know anything about A/C) and it bubbled a lil but and that was it.
The compressor is a remanufactured compressor, the owner I bought it from just put it in a month ago, put another one from the same place in 2 months before that, do you think this one is Sh** too?
Im not gonna have his warranty replace it for it to break again. I have a spare one (factory) but its from a car that wasnt converted to 134, will it work.
Old Aug 10, 2003 | 12:17 PM
86FyrBrd's Avatar
TTT
Old Aug 10, 2003 | 12:27 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
the compressor you have will work just fine, just dont forget to charge the system with oil after filling it with the 134a, green stuff on the back of the compressor? hmm got me on that one.. maybe some kidna dye added to the refridgerant so find a leak.
Old Aug 10, 2003 | 03:23 PM
86FyrBrd's Avatar
Whatever came out of the schraeder valve is the same color as the stuff on the back of the compessor. Its kinda like the color of perfectly clean coolant. Maybe even a lil greener.
Old Aug 10, 2003 | 11:58 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
brian....
when you switch on the a/c, do you notice the sound of the compressor coming on? did you check all the wiring, even the wiring going to the compressor itself?
i know when we sell compressors at work, the invoice prints up an automatic note saying that the dryer (accumulator) and something else must be changed as well to maintain the warranty of the compressor.
possibility they didn't get everything flushed out of the system when they switched to the new refrigerant and it's eating the compressors as an end result?
the green fluid is most likely a dye used to check the system for leaks, we sell a lot of this product to our repair-shops that we deal with.
best of luck with everything
codeysabatini
Nov 10, 2015 04:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
Nervous2
Oct 8, 2015 10:53 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
IROCZ1989
Sep 4, 2015 11:54 AM
