locks are randomly locking and unlocking on their own!!!?
Old Aug 6, 2003 | 12:05 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
of course i figure its a bad ground or a short somewhere but wher ewould it be?
i dont really know how the locks are wired up, i have removed teh fuse so it doesnt do it over-night, and it just recently started to do this.
Old Aug 6, 2003 | 01:00 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
did you happen to tighten the switch on the door? Mine did this and i loosened up the switch and it stopped.
Old Aug 6, 2003 | 01:29 AM
Vader's Avatar
I've also seen that occur when the membrane switches in the door get contaminated with water, begin to corrode, and the copper oxide creates a conductive path without even having the switches depressed.
Either that, or you car is "posessed" and you should get out and run away as fast as you can...
Old Aug 6, 2003 | 01:44 AM
HamSpiced's Avatar
i always wondered why there was blood all over the seats and floor when i bought it........
i think its the fact the switches are sorta wet....its really really humid out today, so maybe ill take the switches apart and clean them....thanks fellas.
Old Aug 6, 2003 | 11:31 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Also, if you have remote locks... or maybe the car had keyless entry at some point, you may want to check and see if the receiver could be causing your problem. In John (the name I gave my winter car) my doors used to do the same thing and my truck would release at random as well. That was no fun considering I had an expensive sound system in it at the time.
I thought that it was a ground or something at first as well, but I found out later that the car had origionally had a keyless entry system. When I found the receiver and pulled the wires out... the problem stopped.
Old Aug 6, 2003 | 11:39 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I had the same problem. I had the windows down a little to let the heat out while I was at work. It started raining and got the switch wet. I was driving home and the locks would lock then unlock rapidly over and over. I thought "what the hell" Almost caused me to wreck.
I cleaned the switches and all was good.
Old Aug 6, 2003 | 12:05 PM
billb's Avatar
Woops, I put the curse on the wrong car
I will dance the "undo of the looney car locky curse" dance tonight.
Sorry for any inconvinece.
Old Aug 6, 2003 | 05:49 PM
Guest
Guest
Posts: n/a
AHHAAHAHAHAAAHAHAHa
Old Aug 6, 2003 | 10:57 PM
HamSpiced's Avatar
wow, ive been seeing an increase in the amt of post ****** since ive been back...
Yea i accidently left the windows oen for a small down pour earlier so that may be the cause, ill pull the switches next day off and clean them. thanks fellas.
Old Aug 7, 2003 | 07:34 AM
billb's Avatar
Dude, get off your high horse, I was just making a funny since people had already given you the answer to the question.
Don't be a dink:lala:
Old Aug 7, 2003 | 05:37 PM
HamSpiced's Avatar
im not flaming, nor on a high horse, it isnt bad to be a post *****, back in my prime i was one of the worst!
dont take me seriously man, you know how it is to dump a ****load of money in your car then have something else break.....
Old Aug 7, 2003 | 05:47 PM
billb's Avatar
Okay, no offense taken:lala: It is just that usually if someone says ***** and is looking in my direction is looking to tangle. .
Trust me, I know what it is like to dump a ton of money into a car, and still have problems. I have dumped 4k (including cost of car) into mine and have yet to get it running (need more parts, which means more which I have very little of).
Just the fun of the hobby.
Old Aug 7, 2003 | 07:25 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
where are all these new "smilies" coming from??
oh yeah whats wrong with ur car is a ghost
Old Aug 7, 2003 | 07:33 PM
Guest
Guest
Posts: n/a
i have 5k into the car and thats with out the cost of the car... and i'm putting 2k more itno it now for the 2nd motor swap in less then a year.
Old Aug 7, 2003 | 07:34 PM
Guest
Guest
Posts: n/a
and this one is just to be a post *****!!!!
Old Aug 7, 2003 | 10:52 PM
HamSpiced's Avatar
big deal.....member posbird87 put 6000 into his car not including price of the car, and it still isnt drivable. he is sick of it and is selling it for 1200.......
i remember getting introuble for 4-5 IBTL posts....lol
Old Aug 7, 2003 | 10:56 PM
HamSpiced's Avatar
i must of missed the thread but welcome to the boards
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
