How hard is it to replace Tranny Mount?
Old Aug 6, 2003 | 10:41 AM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
How difficult is it to replace and about how long do you think it should take to replace the tranny mount on a 700R? Is it a fairly simple job or complex? Thanks for the help!
Old Aug 6, 2003 | 11:06 AM
bigals87z28's Avatar
Car: Check The Sig
its really not that hard to replace.. just a pain to set up... you need to have your car up in the air on jack stands or a lift... then support your trans with a jack or a trans jack. The way i would do it is unbolt it from the trans... then unbolt the trans cross memeber, take off the mount.. swap new one on, bolt cross member back up .. bolt trans mount back on...
Old Aug 6, 2003 | 01:20 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I did this one a while back, wasn't too tuff at all. Big Al's procedure sounds about right, but I never unbolted the cross member. I just undid the actual mount bolt, and I was able to tilt the whole engine tranny combo up the little amount that was needed to slip out the old one and slip in the new one. Total time ~ 20 min.
Old Aug 6, 2003 | 07:02 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
it is super simple....most people drop the cross member just because its 4 bolts....
Old Aug 6, 2003 | 07:13 PM
Guest
Guest
Posts: n/a
LOL i can do it when i'm drunk... take off the one bolt on the trans mount then jake uip the trans then unbolt the 4 bolts of the cross member and then the 2 other bolts on the moutn and your done its off bye bye then put the new moutn out ptu the two bolts on fo rthe trans mount then put the 4 bolts back on the cross member then jack the trans back done then put the last bolt on the trans moutn and your done... like i said i can do it drunk LoL
Old Aug 6, 2003 | 07:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On a "difficulty scale" of 1-10, I'd put it at about -3. It's easier than a tune-up; maybe a little more difficult than changing the oil, but not much.
It will take longer to get the car jacked up and supported on stands than the actual job will take. Make sure you use jack stands.
Old Aug 8, 2003 | 02:15 AM
Trace Cook's Avatar
i agree with the cross-member technique....
if it's a console shift set-up...you might tear the boot seal....a problem that occurs on older vehicles in hot climates (like here in Vegas).
Old Aug 8, 2003 | 11:27 AM
Car: Check The Sig
I would only take off the CM because i dont want to jack up the trans too much.
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
