how come i have no power?
Old Oct 21, 2000 | 04:49 PM
daniel dekay's Avatar
ok, i just swapped out my 305 lg4 for a gm 350. my sig has the mods. it passed smog last week so i got all excited. i have been away at college for the month while my dad has been breakin' the car in. well, i came this weekend to take it back to school. i drove it this afternoon for the first time since it has had its new engine. i put the pedal to the ground and felt almost no response. it stutters terribly at anything above 3000 rpms. whats wrong here? the smog tech said i have a code 24, what is that and is that the effect? is this is a tranny shifting problem? a linkeage problem? i need some serious help. it almosts seems slower than my old lg4. it only has 150 miles on the new engine. i have no times at the 1/4 mile to compare but i can tell it feels sluggish.
thanks
daniel
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers, new red paint and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. sawpped (or in the process of) 305lg4 for brand new 350. TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
Old Oct 21, 2000 | 07:50 PM
Lounge Lizard 6's Avatar
Code 24 should be the vehicle speed sensor (VSS). It supplies the ECM with a toggling 12v signal. This could keep the converter from applying and affect your idle speed when you decelerate. Basically the car's computer doesn't know how fast it's going.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Oct 22, 2000 | 08:52 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What carb are you runnig? Are you back to the ccc and dist?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 24, 2000 | 01:18 AM
i dont know what ccc or dist is?
i have a quadrajet 4 bbl carb. it hasnt been rebuilt but i did take it apart and use fresh gaskets. could the carb be the problem?
its really annoying to not have any power just a studder in that range in rpms.
daniel
Old Oct 24, 2000 | 04:54 PM
BLACK Z's Avatar
Car: 86 Z28
ccc stands for computer controled carb, and the dist, are they orignal, if I am not mistaken you change to a none computer controled carb or dist.
Old Oct 25, 2000 | 02:51 AM
yeah, the carb is original, i just replaced the gaskets on it. the ECm is a different story. i had to replace it cuz it took a shi@ very soon after start-up. the TECh did all the expensive work and testing. i am re-using the stock prom in some remanufactured ECM. any ideas????
Old Oct 25, 2000 | 06:34 AM
BLACK Z's Avatar
Car: 86 Z28
The stock prom for the car? or the stock prom for the computer? I though you had a jet chip? Where is your timing? Is the power ****ty after the new gaskets? Did you retune the carb? What exasut are you runnig? did you do a complete tune up when replacing the motor?
Old Oct 26, 2000 | 02:06 AM
the prom is stock for the car, the ECM didnt come with one, the TECH said it would cost me another 70 bucks for another one just like mine, so i reused it. i had a jet chip, i put 20 miles on it, then i took it in to see what the troubles were. thats when the TECH diagnosed that my computer was bad(it wasnt grounding its actuators) so the SES light would never go off and he couldnt get any codes. so he said to just use the old prom and not bother with the jet chip. i still have, should i put it back in?
the timing is stock i beleive cuz it has to be to pass cali smog, i think?????
the power is there at low rpms, but once i pass like 2000 or so, it boggs. it feels like it hasnt been warmed up, but it does that anytime, on the freeway and such. it only happens when i stomp on the gas. it wont bog when its in park while i just push the pedal slowly down. i dont think i can re-tune the carb because i was under the influence that the ECM did all that carp for me. am i wrong? the exhaust is Edelbrock TES headers with stock cat and flowmaster catback exhaust. when i replaced the motor, the cap, rotor, plugs, wires and coil were alla replaced with new stuff. it passed smog, so i figured everything was fine. but it just boggs and studders at high rpms and it pisses me off cuz i spent alot of money on this little project.
thanks
daniel
Old Oct 26, 2000 | 03:56 AM
Ski89Z28's Avatar
Years ago in the earily 70's I had a truck and all was fine. Did some work to it and took it out to see how it was .... same problem as yours. It would bogg at about 2000rpms and ONLY in gear. I found out it was the fuel filter!
REMEBER this is on a 1969 vechile!
That was it but it was weird how I could rev it in netural but it would bogg in gear.
I don't know if it is your problem but it is a cheap quick repair.
Good Luck!
Old Oct 26, 2000 | 06:43 AM
BLACK Z's Avatar
Car: 86 Z28
Put the jet chip back in, When you ordered the chip which one did you order? I would go to the nearest gm dealer and get a set of dr rod's for the secondarys, and a b or g hanger from edelbrock, jegs has them, that is what I did and it made a nice diffrences. You should have the carb check to you should have the tps set, the mixture control set and even the choke, If you don't know what you are doing bring it to a gm dealer and let them do it, it should cost no more than a 100 bucks. If you are going to bring your car to a shop make sure it is a good or you will just be wasting your money.
Old Oct 26, 2000 | 06:49 PM
i ordered the jet chip, model stage 2 california chip for an 86 camaro with a 305lg4 engine with 4 bbl carb. ill go ahead and install it when you reply to this message, just to make sure you still want me to put it in. how hard are those rods to install? and any gm dealer has them? What are B and G hangers? what do they do?
i havent got the foggiest idea how to adjust my carb cuz i dont want to deal with the electrical connections and all that other junk that surrounds it. im not a total retard tho, i can adjust the mixture screws, i just thought the ECM did that for me. am i wrong on that?
SKI89, i replaced the fuel filter when i put new gaskets in the carb, i hope it still works, it only has like 300 miles on it.
thanks for the help
daniel
Old Oct 26, 2000 | 09:21 PM
BLACK Z's Avatar
Car: 86 Z28
Any gm dealer should be able to get them for you, I am not sure on the part numbers though, the hanger is what holds the rods in the carb, you will see it by the secondarys on the carb I sugest you change them, tehy are cheap I am using the g hanger and dr rods. Bring the car to a dealer and let them adjust it you will be better off, the ecm controles the carb but it still needs to be manualy adjusted first, it can only control it so much. I would also put the chip in I noticed a big diffrence, I am trying to find a 350 chip though.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
