chips
Old Oct 26, 2000 | 07:05 PM
89RS+'s Avatar
chips
I HAVE A 305 TPI. WHEN I SWITCHED IT FROM TBI I USED THE 350 ECM. SO I WOULD LIKE TO GET A JET STAGE 2 CHIP SHOULD I GET THE ONE FOR THE 350 OR THE 305.
Old Oct 26, 2000 | 08:16 PM
Vader's Avatar
89,
You could get the high-performance chip from Frito Lay. I hear that the WOW! chips cause some really high-performance once the olestra kicks in...
As for your car, the ECM for the TPI system is the same for either the 305 or 350 - part no. 1227165. The PROM for the 350 will tend to run your engine on the rich side constantly, even with the smaller 305 injectors. I would suggest a PROM for a 305, since the air flows you will experience at most operating ranges will be more like what the 305 PROM expects and to which it can calculate fuel delivery correctly.
Even if you have a highly modified 305, the air flows at a given RPM are going to be appropriate for a 305, not a 350. The aftermarket programmers should already have taken this into account and modified fuel and spark advance tables accordingly.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 26, 2000 | 09:10 PM
89RS+'s Avatar
SORRY FOR NOT TELLING YOU THIS EARLIER BUT DURING THE SWAP EVERY PIECE I USED CAME FROM THE 350 LIKE THE 22# INJECTORS SO DOES THAT CHANGE ANYTHING. I ALSO PORTED AND POLISHED THE RUNNERS GUTTED THE MAF PUT HEADERS ON IT GUTTED THE CAT AND USE NO MUFFLERS SO DO YOU THINK IM ALL RIGHT WITH THE 22# INJECTORS. AND THE 305 CHIP LIKE YOU TOLD ME.
Old Oct 26, 2000 | 09:12 PM
89RS+'s Avatar
SORRY I ALSO PORTED AND POLISHED THE PLENUM
Old Oct 27, 2000 | 01:31 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Yeah do what vader said- and hey can you do us all a favor and type in smaller case letters? it seems to me your shouting
Steve
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
