CRAAAAAAAAAAAP!
Old Oct 27, 2000 | 07:22 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
CRAAAAAAAAAAAP!
My engine just started making a horrible knock. It sounds like it is coming from the driver's side head, so my initial thought was a stuck valve. But when I removed the valve cover none of them seem to be sticking. Any ideas what it is?
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Oct 27, 2000 | 07:25 PM
IrocManiac's Avatar
It could be an exhuast leak. However, most of the time they make a clicking sound not a knock. You could have spun a bearing on the crank but you said you thought it was coming from your heads...so I would guess an exhuast leak.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 27, 2000 | 07:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It may be a wiped out rocker ball... try listening to each valve assembly with a piece of heater hose as a stethoscope, and see if you can locate the source of the noise; then a little inspection should reveal the cause.
Old Oct 27, 2000 | 07:46 PM
Car: 88 GTA
No, it is definately not an exhaust leak. There is a definate metal-on-metal sound.
I'll try listening to the rockers individually, thanks.
Old Oct 27, 2000 | 10:52 PM
Car: 88 GTA
Well, I figured out what it is. Exactly what I was hoping it wasn't... I spun a bearing. I noticed that there was zero oil pressure, and after draining the oil and cutting open the filter I found metal everywhere.... I don't know if my oil pump failed or what. But now I get to call my parents tomorrow and tell them the wonderful news.
So, anyone know where I can get a good deal on a decent long block?
Old Oct 27, 2000 | 11:03 PM
IrocManiac's Avatar
That is what I was afraid of. I have the same problem myself but for some reason mine is really living up to the chevy name LIKE A ROCK even though I don't have a truck. It has been doing it for well over a year and my mechanic still says it has a good 10k left in it....pretty wierd...usually a spun bearing kills the crank rather quickly. But I don't drive extremely hard. In fact I have been babying her for a while. Good Luck
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Oct 29, 2000 | 02:43 PM
Car: 88 GTA
Well, I pulled the engine last night. I spun the large end rod bearing on the #3 cylinder.
At least the upside is I can build myself and engine now.
Old Oct 30, 2000 | 11:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I always wondered how people knew they spun a bearing before tearing the motor down- just look for metal in the oil filter?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 30, 2000 | 12:53 PM
Car: 88 GTA
Not just metal, but if it's really shiny, silvery metal like a bearing is made out of, that's a good assumption of what it is.
