broken key in ignition...
Old Aug 13, 2003 | 11:06 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
not my car, but my step-daughter's car... geo prism, i think. anyways, tip of the key is broken off in the ignition and the key still works to turn the ignition with that piece in there, but is there a trick to removing broken pieces or is it a pro only job? i don't have much time to work with, so i don't want to "finish" breaking what's already broken by not being able to get it out completely... thanks...
KAM
Old Aug 14, 2003 | 12:40 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
get a small screwdriver, flathead
get an old speaker or subwoofer
run the screwdriver in one direction over the magnet a few times
you've just magnetized the screwdriver
if your key has iron in it, you will recover that piece.
Old Aug 14, 2003 | 12:47 AM
NTChrist's Avatar
Hmmm, magnetic brass???
Get a pair of needlenose.
Old Aug 14, 2003 | 01:52 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
how are needle nose going to fit in the slot for your key?
Old Aug 14, 2003 | 02:09 AM
EvilCartman's Avatar
Car: '82 Z28
Grind till it fits
Old Aug 14, 2003 | 08:47 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
i dunno if it would be strong enough, but some rare-earth magnets (VERY strong, small, and inexpensive...radio shack) can pull just about anything from a few inches distance away....
Old Aug 14, 2003 | 08:52 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
It's a brass key man, as mentioned above.
Brass is not magnetic.
Try a dentist type pick, tool supply places would have them. If that doesn't work, take the ignition unit apart.
Old Aug 14, 2003 | 12:13 PM
demonchild's Avatar
to hard man. new ignitions are 15 bucks at any local parts stores and most lend the tool needed to pull the ignition out and put in the new one. however if it still works and you still need the key to start it, why worry?
Old Aug 15, 2003 | 12:25 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, just get a new key and ingition set.. they are cheap and easy to swap.
Old Aug 15, 2003 | 02:30 AM
NTChrist's Avatar
Thanks Tom. Sometimes you need to S-P-E-L-L it out for people.
Old Aug 15, 2003 | 02:31 AM
NTChrist's Avatar
This is also a good option, but I paid $49 for my VATS ign. lock cyl.
FYI
Old Aug 15, 2003 | 03:49 PM
Car: '91 Z28
Axle/Gears: 323's
thanks for the replies... sounds like it'll be better off just to replace it... i just didn't want to get in there with some sort of make-shift tool, get the broken piece stuck elsewhere and then not be able to get the rest of the key in at all... and then be forced to change it out now...
KAM
Old Aug 15, 2003 | 05:20 PM
Guest
Guest
Posts: n/a
i'm just take it out of the car and beat it ont he ground till the part falls out... if you get really pissed off and slam it into pices then go get the new one :-D
Old Aug 18, 2003 | 02:39 AM
demonchild's Avatar
i'm just take it out of the car and beat it ont he ground till the price fell out... if you get reallt pissed off and slam it into poces then go get the new one :-D
that would work...
FYI
and people want vats on their cars for more problems and more exppensive parts. good thing i dont have VATS
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
no green
Jan 9, 2016 09:22 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
