Loud hollow clunking sound from rear...
Old Oct 30, 2000 | 02:41 PM
EO273KiD's Avatar
Ok, I have an 1989 IROC Caramo with a 350, I have only had it for about a week and now there is a loud hollow clunking sound comming from the rear. It only happens during acceleration and while cruising. If I shift into neutral it goes away. I am thinking U joints or the rear end gears. I jacked up the car and there seems to be a some play when I turn one wheel before the driveshaft moves. Ideas? How much do new gears cost? Thanx guys...
Old Oct 30, 2000 | 03:52 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Sounds like a broken tranny mount. Look at getting a urethane part.
Old Oct 30, 2000 | 04:47 PM
ede's Avatar
ede
i agree look at the trans mount. if it's broke buy a es poly mount.
-=ICON MOTORSPORTS=-
Old Oct 30, 2000 | 06:11 PM
EO273KiD's Avatar
No, it is the rear end. As I was driving home, (it was a constant clunk that got faster and faster as I went faster) I came to a stop and went to take off and BAM! Couldn't move. My teeth have sheered off or something. I heard that ford rear ends are a lot stronger than stock so maybe I can get one of those? Ideas? Can I replace just the gears inside? Prices? Thanx.
Old Oct 30, 2000 | 06:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like a tooth sheared off the ring gear... bummer
You'd probably do better to just get another rear end than to try to fix that one. Gears for those (9-bolts) are HIGH, and you'll have to buy the bearing kit, lube, labor, etc. It would probably run up a $1k bill. You should be able to get one at the boneyard for about half that.
Old Oct 31, 2000 | 09:11 AM
danomano's Avatar
My friend had a 78 that was doing the samething we were drive slow trying to figure out were it was coming from then blam screech no more movement. It turn out that the spider gear had blown apart and lock up the whole thing. We change out the spider gear refilled with oil and all was normal.
Old Oct 31, 2000 | 09:44 AM
CamaroZ_85's Avatar
he doesnt necessarily have a 9 bolt...
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 31, 2000 | 10:10 PM
EO273KiD's Avatar
It is a 9 bolt. It doesn't have spider gears.There is a pinion gean, and a larger ring gear. Half the teeth are broken off of the pinion and all the teeth on the ring gear are bent, twisted. I called Summit, and they said they have a set of 3.7? gears that should fit for around $200. Thats what I am planning on doing, since I had 3.2? gears already.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
wanext
Oct 6, 2015 12:18 AM
loud91rs
Oct 5, 2015 10:05 PM
Fanatic1074
Oct 2, 2015 03:47 PM
