Vats problem I think?
Old Aug 19, 2003 | 03:06 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
I just replaced the starter and my car wont crank. I checked my error codes on my ecm and it came out as 53 which has something to do with vats right? I also noticed that my vats wires were spliced in to. those are the two wires that go into a connector under the column right? got any ideas what the problem is?
Old Aug 19, 2003 | 10:28 PM
onebinky's Avatar
Your vats connector will have two wires going into it on either side, and the wires are usually in a white or orange covering. What is spliced into them?
With the VATS, it could be one of a few things giving you problems. It could be the resistor in the key going bad, it could be a bad connection (probably this one since you said the wires are spliced into), or a bad module.
Take care,
Matt
Old Aug 19, 2003 | 11:11 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
I looked at the wires closer and they just have heat shrink around them. iM thinking about buying a custom chip from tbi chips.com that disables vats will that solve my problem if its in the wiring or in the module
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
