cant get fog lights to turn on
Old Nov 2, 2000 | 06:28 PM
ScreaminDeamin85Z's Avatar
can someone please tell me if there is an inline fuse for the fog lights. i checked the fuse box and none are blown and not one says"fog lights" so i am at a stand still with my head up my a** trying to figure out what is wrong witht these stupid things!the bulbs are brand new and i tsted them on car battery and the work, so what now?
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
Old Nov 2, 2000 | 08:25 PM
Vader's Avatar
Camaro or Firebird? (There is a slight difference in wiring.)
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 2, 2000 | 08:29 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Is your switch working? They have a tendency to break and not properly "switch on"... check to see if a light comes on when you turn the switch on...
Old Nov 2, 2000 | 08:48 PM
Todd 92 Z's Avatar
There should be a relay some where in line to the fog lights, it might be bad, try replacing it. Also make sure your high beams are off,fog lights will not come on with high beams on.(you probably know that but it's worth mentioning.) It's gotta be something in the wiring between the lights and the fog light switch so just check everything, but I would find the relay and try that first since you said you know the bulbs are good.
Old Nov 2, 2000 | 08:54 PM
Car: Death Mobile
Engine: 666 c.i.
Also, make sure you check ALL of the connections, that they are clean AND give them a nice coating of dielectic grease.
I had a problem with a loose connection and the lights would go "on and off" due to vibration. If I banged on the front facia, they could go "on and off". After I cleaned all the connections and made sure they were properly connected together (on Firebirds you sometimes don't get the wire to connect properly from the male connector on the bulb to the female connector in the holder) they all worked fine.
I also had a broken switch one time, where they would only work IF I held the switch down.
Old Nov 2, 2000 | 10:06 PM
Vader's Avatar
SD,
If you have a Camaro, I don't know where your relay is located, but if your's is a Firebird, there is a relay at the firewall, next to the hood hinge arms:
Just for reference, the factory wiring will NOT allow the driving lights to turn on when the high beam headlamps are turned on. If your high-low beam switch is hosed, your driving lights will not operate.
Later,
Vader
"Make Me Bad"
jaridjohn
Jul 8, 2024 03:49 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
