High 13's-LOW LOW 14's
Old Aug 20, 2003 | 04:19 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
What would it take to run these? With low end power, keeping the t-5 tranny. The t-5 won't be driven hard everywhere, because it has to stay. I'm thinking, full exhaust, FINALLY putting my intake on (would I have Computer problems if I put it on? I heard about some), some suspension goodies, and anything else I may need. What do you guys reccommend?
Old Aug 20, 2003 | 04:59 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
you will need a cam for sure. I don't think 13.99 is likely on a 305 without a cam or spray. I'm sure someone will jump in here and say they did it but if you're going to have the intake off it would be an easier time to do the cam and lifters than doing them seperately. New timing chain and some gaskets and you're good to go.
That stock cam is holding you back.
JUST my opinion.
Old Aug 20, 2003 | 05:05 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The setup in my sig should be good for mid-14s. To hit low-14s and high-13s you will need 3.73 gears. A bit lumpier cam might help, too, for the top end charge. Maybe a Comp XE 262 or Crane PowerMax 266.
Heads and exhaust are absolutely mandatory or you won't get there.
Old Aug 20, 2003 | 05:42 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
I guess I forgot to mention its a L69 H.O. It has 3.73 gears stock
Old Aug 20, 2003 | 05:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
its very possible but it would probably be cheaper in the long run to buy a 350 block and start there, other things ya might wanna think about are some tubular control arms, some lca relocation brackets, stickier tires, maybe an air bag, and as with any f-body your planning on takin to the strip some subframe connectors.
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
