oil pressure problem. please help.
Old Aug 20, 2003 | 07:50 PM
92camaro's Avatar
I have been having a problem with my oil pressure dropping alot when i brake really hard. If I run the car hard then brake the oil pressure drops to like 5psi. The oil pressure is fine when idling and just normal crusing. What could be the problem. I need to fix this quickly. Thanks
Old Aug 20, 2003 | 07:56 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
low oil level or maybe the pickup came off of your oil pump.. any other ideas?
Old Aug 21, 2003 | 10:23 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
The hard stoppong may cuase the oil to move away from the pickup, cuasing the low pressure. Sorta like how gas moves away from the sender causing the guage to move on hard braking and acceleration.
Matt
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
