Does this mean i dont have a speed limiter?
Old Nov 2, 2000 | 01:03 AM
Josh 91RS's Avatar
Ok so im going on the freeway tonight...(Ive only had my camaro for about a month and 3.5 weeks it was being painted)...and happened to get my 91 RS up to 110...and further. It felt like it had a lot more to go and i was probably at about 115 before i got to my exit :0)...Ive heard people say the speed limiter cuts off at 110...does this mean my limiter is possibly disabled or i dont have one?
Old Nov 2, 2000 | 01:42 AM
Mo's Avatar
Mo
i'm not sure but i think if you had a z car without z-rated tires from the factory you had a speed limiter
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
Old Nov 2, 2000 | 02:31 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yeah, only cars with 16"s had no speed limiter on them. May be exeptions tho, but all 15"s should have the limiter. Stock 15" tires were only good to 120mph or so.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 2, 2000 | 07:00 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I have 16" rims, and I have a speed limiter. My car is clocked for 190km/h, and it will cut out slightly after 190 and drop to about 185 before kicking in again.
How do you get rid of the speed limiter???
Godti
'89 Trans Am (Red)
305 TBI 5spd
[This message has been edited by Godti (edited November 02, 2000).]
Old Nov 2, 2000 | 01:28 PM
92GTA's Avatar
I have the 16" rims and my speedlimiter kicks in at 135......I have 2.73 gears too.
Old Nov 2, 2000 | 03:58 PM
MrJ's Avatar
MrJ
There should not be a speed limiter on WS6 Firebirds.... I virtually maxed my car out, I had it up to 140, and there was no speed limiter. None of the cars equipped with 245/50/ZR16s had the limiter, to my knowledge.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
Old Nov 2, 2000 | 04:06 PM
Blade's Avatar
You need a custom chip for that. I make em
Old Nov 2, 2000 | 04:18 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Josh...I think you didnt go fast enough for it to kick in. My 91 RS with the 16" tires would go to about 118 and it would just die. The speedometer is probably a little of at that speed.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Nov 2, 2000 | 04:41 PM
Josh 91RS's Avatar
Ok thanks guys, i guess ill just have to take it a little further to see whats up lol. How fast have some of you other guys with stock 305tbi's taken it? Just wondering. Man, i cant wait till i get my damn 350 or 383 in here.
Old Nov 2, 2000 | 10:23 PM
Andy89RS's Avatar
I took mine to 115 before the limiter kicked in. After my high tech speed limiter eliminator mod (broken speedo cable) I've gotten it to 135 and was still accelerating when I had to let off. I'd guess I would have topped out at 145 or so...
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Nov 2, 2000 | 10:34 PM
Hulk0202's Avatar
The speed limiter should kick on at 115 not 110, and you dont need a custom chip to take care of that. There is a way to bypass it. I think its listed in the tech articles.
Old Nov 2, 2000 | 10:38 PM
Hulk0202's Avatar
https://www.thirdgen.org/newdesign/tech/unlimited.shtml
Heres where the article is
Old Nov 3, 2000 | 12:03 AM
bill wilfred's Avatar
i hope you not planing on bypassing the limiter just so you can go as fast as you can on non zrated tires through downtown. thats just stupid and dangerous
Old Nov 3, 2000 | 12:31 AM
dudelovett's Avatar
Ive buried the needle on mine (190 km/hr) and nothin was shuttin down on mine!
1991 Firebird Formula, 305, TPI, Auto...stock till I get some money!!!
Former owner of an 88 2.8 Firebird....RIP
Old Nov 3, 2000 | 01:14 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
actually i got pulled over by a cop clocked at 115!!! i had been hitting the speedlimiter off and on around the time he pulled me over...i passed a group of cars (where he was) (i didnt see him) i flew by the pack still accelerating when he got the reading...i hit the speed limiter shortly after
Rick
90 Camaro RS 305 TBI
350 on the way!!
Old Nov 3, 2000 | 07:37 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
YOu have a TPI, I am getting the impression it was the TBI units that have the speed limiters. I could be wrong, but I know it kicked me off the gas at 190 km/h.
Godti
'89 Trans Am (Red)
305 TBI 5spd
Old Nov 3, 2000 | 09:49 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
TPI cars could have them too. My old 89 IROC convertible had the 235/55-16 tires & 110mph speedo...it wouldn't get over 110 w/o the limiter kicking in.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Old Nov 3, 2000 | 10:50 PM
Vader's Avatar
Josh,
ALL TPI and TBI cars have speed controlled fuel cutoff programmed in the ECM PROM. Both TPI and TBI Federal cars (cars that were originally delivered outside California) with 15" tires and wheels had the fuel cutoff programmed at 118 MPH on the VSS input. TPI cars that were delivered with 16" 'Z' rated tires have the fuel cutoff programmed at 254 MPH, not infinite speed.
The ECM MUST have a value programmed in this parameter to operate, so the TPI 'Z' rated cars got the highest value allowed in the ECM programming. (There are 255 possible settings - 0 through 254, so the 254 setting is the highest allowed.) In practical use, the limit would never be reached so it is considered to be "unlimited". The only cars that ever had a problem with this were powered by John Lingenfelter. He must have found a back door around the problem to get 304 MPH on his stock-bodied '91 Formulas.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
