Car Won't Start!
Old Aug 23, 2003 | 11:24 PM
jeff's Avatar
Car Won't Start!
My 92 bird won't crank and I can't figure out what's wrong with it. Lights on the inside come on, stereo works, but when you turn the key there is nothing. No sound at all. I keep the car in storage and it has been there for about a month. Battery is good. I have a Viper alarm with remote start but I don't know if it could cause the car not to start (safety feature or something). Any ideas on where to start? Is there a certain fuse I could check? Checked the VATS fuse and it was good. Help....
Old Aug 23, 2003 | 11:27 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Check the starter, myn wouldn't do NOTHING with my starter, had to get it rebuilt.
Old Aug 23, 2003 | 11:33 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
possible cenarios....dead starter solenoid which would definitly cause your problem....the less likely one being your an idiot (i did this before) and dont realize the tranny needs to be in park to start the car im wondering if its not the solenoid whatever switch is thrown when the car is in park that lets you start it could be messed up?
Old Aug 24, 2003 | 11:28 AM
jeff's Avatar
i just got the started rebuilt about a month ago and the car is in park. I'll check the starter solenoid next.
Old Aug 24, 2003 | 06:21 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
yeah if its just clicking and nothing is happening chances are its the solenoid.
Old Aug 25, 2003 | 10:41 PM
jeff's Avatar
there is no clicking, just complete silence.
Old Aug 26, 2003 | 01:33 PM
Greygoat's Avatar
I have the same problem after i run the car still have not figured it out but to get a new car
Old Aug 27, 2003 | 02:13 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
okay the click is just of the key turning over it seemed to make a little click when it turns over and nothing happens...more of just metal hitting metal. Id check you solenoid for sure.
As far as grey goat is concerned if you are having a similar problem but its a hot start problem it is also probably your solenoid. These cars run extremely hot and heat is one of the things that will make your solenoid not work (age doesnt help). The solution is to install a remote starter solenoid. There is instructions on how to do this on the main thirdgen.org site tech articles area. good luck to both of you with your problems.
Old Aug 27, 2003 | 02:01 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
check your battery connections and make sure they are tight..
dumb answer, but mine was doing the samw thing. sometimes it started other tiems it did nothing like a dead battery (but i had juice going to everything and everything worked off the battery) i bought a new starter and i was going to put it in and i checked the battery conections and it was very lose. check the terminals
Old Aug 27, 2003 | 03:13 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
19doug90 says use a remote starter solenoid. I think he means a remote starter switch. It installs between the large terminal on the starter and one of the small terminals on the solenoid. You could even use a screwdriver but be careful, the large wire is directly from the battery. Make sure the car is in neutral. If this does not work, do what trans_am_ta_84 says. After a car sits for awhile, the terminals and clamps can start to corrode, making the connection bad. The go back and test the starter again manually. If it cranks, the problem is somewhere else, like a fusible link. If the starter works, but not with the key, turn the key on, like you are starting the car, make sure the car is in neutral and blocked, use the remote starter. The car should start. If not, look for the links.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
