Crank/damper question
Old Aug 24, 2003 | 01:59 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
Anyone knows this or could measure?
I need to know the distance from the center of the crank out to the damper. If you know what I mean?'
I want to make sure its correctly mounted............
thanks!
/N.
Old Aug 24, 2003 | 06:28 AM
ede's Avatar
ede
the dampner bottoms out aginst the lower timing gear and then you tighten the crank bolt aginst the dampner. there is no measurement to check.
Old Aug 24, 2003 | 07:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
OK...........
Thanks!
Old Aug 24, 2003 | 11:58 AM
Vader's Avatar
60-65 ft/lb for a regular small block Chevy.
Old Aug 24, 2003 | 12:11 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I removed my pully and the "hole" behind it was full of oil?
is this normal?
Old Aug 24, 2003 | 12:38 PM
Merlin's Avatar
That "hole" behind it that you are referring to is probably the inside of the timing cover. Having lots of oil in there is a good thing. Your timing set will thank you.
When you reassemble, make sure you apply a layer of clean grease or heavy oil to the balancer hub so you don't damage the seal in the timing cover when it slides past.
You might also want to get your hands on a 5-6" piece of 7/16" - 20 threaded rod and a mating nut to pull the damper hub back onto the crank. Using the crank bolt to pull the damper on can have disasterous consequences. Search the archives for "Stripped Crank Bolt" for the reasons. Hammering the balancer back on can also cause problems with the balancer, main bearings, and possibly the crank if you get it started worng.
Old Aug 24, 2003 | 12:42 PM
Merlin's Avatar
OOPS! I just noticed your location. Good luck finding a piece of 7/16" - 20 threaded rod in Scandinavia. Then again, it might not be that difficult.
If you get into a bind and aren't in a real hurry, PM me with a mailing address and I can ship off a "kit". Parcels to Norway take about 8-10 days, so I'm guessing it would be about the same for Sweden.
Old Aug 24, 2003 | 03:59 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I havent removed the damper, the oil was "in the damper" just behind the pulley.........................
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
