starter install.
Old Aug 25, 2003 | 10:01 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
starter install.
im getting really frustrated, i can't seem to get the starter in. i get it in the pocket, but can't rotate it to fit in properly. what do i do?
Old Aug 25, 2003 | 10:09 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: starter install.
When you say you can't rotate it to fit properly.... are you sure you got the right size 'tooth ring gear' for the flywheel to engage (they come in two different sizes.... one's 153, and the other is 168)?
Cheaper starters usually don't work for both applications, only the more expensive one's can be adapted for either/or.
Unless I'm mis-understanding you're explanation?
Old Aug 25, 2003 | 10:23 PM
Car: 83 Trans Am
Re: Re: starter install.
my old one died, and we are attempting to install the new one, but its not going in at the right angle, the oil pan is in the way and the exhaust, any suggestions are appreciated
Old Aug 25, 2003 | 10:29 PM
Re: Re: Re: starter install.
Did you match it up to the old starter, and is it the same exact size? If so, unbolt the Y-Pipe from the exhaust manifolds (4 bolts, two on each side)..... this will give you better clearance for the install.
If it's the same pattern as the original unit.... then the oil pan is not a concern. You just need some room to work with. Remember, it's always easier to remove something, than it is to install it (not including rusted bolts of course lol).
It'll go in, just don't force it, and don't get frustrated. Give yourself more room to work with, and remove the Y-Pipe from the exhaust manifolds....
Old Aug 26, 2003 | 01:15 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Assuming you got the correct starter, jack your car up and take off the wheel, that will give you room to see what your doing. The oil pan won't be in theway if you have the right starter. you gotta worm it up through the exhaust and eventualy you''ll get it to go in place. Thenits just a few wires and two bolts are your done!!!
Old Aug 26, 2003 | 01:24 PM
BADBIRD009's Avatar
its a tedious job but it will go in! i had to pull tranny lines slighly out of the way to get the starter in there. be carfull not to pull them too much or it will break.
just hope you dont have the same happen to you that happend to me. i got the starter installed and it was no good. so i took it off and returned it. they checked the one i brought back and sure as **** it was bad. then once i got the other new starter installed, it needed shimmed! took 3 or 4 times to get it right.
Old Aug 26, 2003 | 01:45 PM
Engine: Mild 350
Yeah that was a lot of , I'm glad I didn't go through that problem like you did....
Old Aug 26, 2003 | 01:56 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
My dad never had a problem with myn, maybe its cause he's done *** knows how many starters, but we had it off in 15 minutes, all we did was jack it up, put a towel for him to work on, and pulled it off.
Old Aug 27, 2003 | 10:24 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
When I did mine, I finally got the bad one out with a fair amount wiggling and twisting. However, I could not seem to duplicate the same combination of wiggling and twisting to get the new one back into the correct position. Of course, holding a 20 lb starter over your head gets old real quick! I ended up removing the selenoid from the starter to make more room, then reinstalling it after it was in close proximity to its necessary position, just prior to bolting everything back up. Yes, it is a real pain, but be patient with it and it will go back in!
Old Aug 27, 2003 | 12:07 PM
Car: 83 Trans Am
its in and working great. thanks for all your help
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
Thaney9
Oct 24, 2015 07:26 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
