blower doesnt work after...quick
Old Aug 26, 2003 | 05:03 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
After my motor swap, my blower doesnt work...is it ecause i didnt hook up any of the original vacuum lines? i tested the blower(it workes) the purple(?) wire is not geting anything
Old Aug 26, 2003 | 09:34 PM
cr125r's Avatar
Car: 1988 trans am
im only thinking this because when i ran a search, people were saying that the vents were controlled by vacuum(i think) so i didnt know if i have the same problem with the blower not working
Old Aug 27, 2003 | 07:23 AM
Vader's Avatar
The blower should work regardless of vacuum. Does it not work on any speed, even High?
Old Aug 27, 2003 | 10:37 AM
cr125r's Avatar
Car: 1988 trans am
nope, you can imagine how bad it is in the rain. i can barely drive it when it rains with no defroster. what would be some things to check?
Old Aug 27, 2003 | 06:39 PM
kidcamarosc's Avatar
i just went through this last week with mine. The blower motor is powered by a fusible link which runs to the ac/vent/heat/defrost switch its a brown wire i think. That switch also sends power to the blower motor switch. My switch for the ac/heat cycle was burnt out so no power was getting sent to the blower switch.
Old Aug 27, 2003 | 07:40 PM
cr125r's Avatar
Car: 1988 trans am
are u talking about right behind the plate that has the controls on it?
Old Aug 28, 2003 | 05:45 PM
yeah.....its the switch that you use to select or ac levels, defrost, etc. if you pull out the whole assembly you'll see a orange switch. I could actually see it where it was burnt. Also before you start pulling the panel apart did you check your relay for the blower motor, could be bad??
Old Aug 28, 2003 | 05:48 PM
cr125r's Avatar
Car: 1988 trans am
i dont know what to look at the relay for...isnt it just a little black thing with 5 or so connections on it? do i just have to replace it?
Old Aug 29, 2003 | 02:10 PM
cr125r's Avatar
Car: 1988 trans am
well, i went out today and tested a bunch of wires, trying to find what worked and what didnt, somehow, all of a sudden, i was getting power(while i was working on it) must have been a loose connection that i fixxed. only problem is that now it only works on high. thanks for ypour help everyone! why would i only have one speed though?
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
