Tachometer Connection Question
Old Aug 27, 2003 | 11:00 AM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
OK, I have the remote mount coil for my 87 camaro with TPI and HEI. I want to set up a tachometer in the engine compartment while I do my tune-up work, IAC and TPS adjustment, timing etc.
Please can somebody submit a picture or instructions on what wire to connect the tach to? I have a Actron digital voltmeter (model c7676 I think) that can do RPM (I also use it for my TPS) and I have an older (1980's) Sears tach/dwell/voltmeter. The problem is that all of the wires connecting between the coil and distributor are not easy to put a probe on.
Any input even with different tachometers would be appreciated. The manuals say the car's tach is not sensitive enough to use during tuneup.
Scott
Old Aug 27, 2003 | 01:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you just need to pick up a tach signal, you should be able to get one on the ground terminal of the coil.
Pete
Old Aug 27, 2003 | 04:14 PM
abcx09t's Avatar
Tachometer connection
OK, I don't have a clue as to where that is?
Also, the connections are all sealed, so how do I get a connection on this ground?
Thanks for the reply.
Scott
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Bull86
Aug 10, 2015 05:43 PM
